Inventor Not Properly Updating
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have a Form in Inventor that allows me to change the Parameters of a design, and have the Assembly change to reflect those parameter changes. The problem is, even when i make a rule that forces an update of the system, not every part gets updated.
I've tried a number of solutions, but none of them have worked.
The changes are made on the part level, but not reflected in the assembly. The assembly notes that an update needs to happen, and that when i manually update the assembly, the changes that I am needing, change and proceed through. My manual update rule is the last rule i have written, but even then it doesn't reflect the changes until after all the rules have run, and I have to manually hit the Update button.
Is there a fix that you know of?
Thanks all
William
