Question on VBA macros for HSM
dr.carsten.stroh
dr.carsten.stroh
Hi and happy new year!
Is there a way to access data of the operations of HSM (the plugin CAM system)?
I would like to read (and write) parameters of milling operations (see screenshot), tool data and setups. I could check and automate the CAM programming than.
Unfortunetly the "Inventor API Object Model" seems not to contain objects of the HSM (Maybe I did not find them? Is there an "extended Version"?...). Is there further documentation, tutorials or examples out there?
Thanks in advance for your support,
best regards
Carsten
Prof. Dr.-Ing. Carsten Stroh
Technische Hochschule Mittelhessen
- University of Applied Sciences -
Curtis_Waguespack
Hi dr.carsten.stroh,
You might search this forum:
https://camforum.autodesk.com/index.php
Here's one related discussion I found:
https://camforum.autodesk.com/index.php?topic=4996.0
I hope this helps.
Curtis
dr.carsten.stroh
Thanks for the answer and the links Smiley Happy
