Inventor new instance on close
- Mute
- Permalink
- Report
Hey
im having a small issue with an invisible document appearing in my taskbar when i close inventor. This appears mainly after i run my app so i mustn't be closing something properly. In summary, here is my document open / save close process
1. Import step file using translator (no open file before import)
Call oSTEPTranslator.Open(oDataMedium, oContext, oOptions, oTarget)
2. Create a document view from the import
Dim oDoc As Inventor.Document = oTarget
oDoc.Views.Add()
3. Process all of the components in this document (not saved yet)
4. Rebuild & update active assembly (document from step 1)
5. Create a temp doc to hold the original ActiveDoc
Dim OldDoc As Inventor.AssemblyDocument = AddinGlobal.InventorApp.ActiveDocument
6. SaveAs the current ActiveDoc into a new location
AddinGlobal.InventorApp.ActiveDocument.SaveAs(PathRoot & AssyName & ".iam", True)
7. Open the newly saved document as a new assembly
Dim NewDoc As Inventor.AssemblyDocument = AddinGlobal.InventorApp.Documents.Open(PathRoot & AssyName & ".iam", True)
8. Close the old doc that i created as the ActiveDoc prior to saving
OldDoc.Close(True)
9. Iterate assembly and SaveAs all components then replacing them in the assembly for the saved ones
This should leave 1 assembly active (the new one) and the old ones closed or is that not the case? Does item 2 actually create another document and is that the rogue document? Somewhere in this process is an invisible document. For every other process, i pass the ActiveDocument through instead creating document instances for example-
Private Sub DoSomething()
'process stuff here
Call NextSub(_InvApp.ActiveDocument)
End Sub
Private Sub NextSub(ByRef CurrDoc As AssemblyDocument)
'do something with CurrDoc
End Sub
The problem highlights when a new project is initiated as all documents need to be closed...
Any help greatly appreciated
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
