iLogic on Design automation service. ThisApplication is null
aignatovich
Advisor Advisor
Message 1 of 8
aignatovich
Hi, guys,
I have a problem with an iLogic rule running on Forge Design Automation service. It works locally, but fails in the cloud.
This is a part of an addin, it is very simple:
public void Run(Document doc)
	var document = inventorApplication.Documents.Open(path);
	var drawingDocument = (DrawingDocument)document;
	// set some parameter values
	drawingDocument.Parameters...
	iLogicAuto.RunRule(document , "Update");
This is a part of iLogic rule code:
System.IO.File.AppendAllText(logFilePath, "Started;")
Try
	Dim oDoc As Document
	oDoc = ThisApplication.ActiveDocument
	System.IO.File.AppendAllText(logFilePath, "got the document;")
Catch ex As Exception
	System.IO.File.AppendAllText(logFilePath, ex.Message)
End Try
And my iLogic rule log file content after executing the WorkItem is:
Started;Object reference not set to an instance of an object.
So ThisApplication was null. What should I change to be able to run this code in the cloud? It works locally...
Replies (7)
Message 2 of 8
I don't know much about running rules on the cloud, but I know I've had issues with ThisApplication.ActiveDocument that I solved by replacing it with ThisDoc.Document. This gets the Document of the component the rule is run in rather than the currently active document. Not sure if it will fix your problem, but can't hurt to try.
Message 3 of 8
WCrihfield
Maybe try getting the application like this:
app = InventorVb.Application
Or getting the document like this:
doc = iLogicVb.RuleDocument
Wesley Crihfield
(Not an Autodesk Employee)
Message 4 of 8
aignatovich
Hi guys, thank you for your replies.
I still have a problem, I can't get an application. I tried this code in the iLogic rule:
If ThisApplication Is Nothing Then
	System.IO.File.AppendAllText(logFilePath, "ThisApplication is Nothing;")
Else
	System.IO.File.AppendAllText(logFilePath, "ThisApplication is OK;")
	If ThisApplication.ActiveDocument Is Nothing Then
		System.IO.File.AppendAllText(logFilePath, "ThisApplication.ActiveDocument is Nothing;")
	Else
		System.IO.File.AppendAllText(logFilePath, "ThisApplication.ActiveDocument is OK;")
If ThisDocument Is Nothing Then
	System.IO.File.AppendAllText(logFilePath, "ThisDocument is Nothing;")
Else
	System.IO.File.AppendAllText(logFilePath, "ThisDocument is OK;")
If ThisDoc Is Nothing Then
	System.IO.File.AppendAllText(logFilePath, "ThisDoc is Nothing;")
Else
	System.IO.File.AppendAllText(logFilePath, "ThisDoc is OK;")
	If ThisDoc.Document Is Nothing Then
		System.IO.File.AppendAllText(logFilePath, "ThisDoc.Document is Nothing;")
	Else
		System.IO.File.AppendAllText(logFilePath, "ThisDoc.Document is OK;")
If InventorVb.Application Is Nothing Then
	System.IO.File.AppendAllText(logFilePath, "InventorVb.Application is Nothing;")
Else
	System.IO.File.AppendAllText(logFilePath, "InventorVb.Application is OK;")
If iLogicVb.RuleDocument Is Nothing Then
	System.IO.File.AppendAllText(logFilePath, "iLogicVb.RuleDocument is Nothing;")
Else
	System.IO.File.AppendAllText(logFilePath, "iLogicVb.RuleDocument is OK;")
If iLogicVb.Application Is Nothing Then
	System.IO.File.AppendAllText(logFilePath, "iLogicVb.Application is Nothing;")
Else
	System.IO.File.AppendAllText(logFilePath, "iLogicVb.Application is OK;")
And I get this:
Started;ThisApplication is Nothing;ThisDocument is Nothing;ThisDoc is OK;ThisDoc.Document is OK;InventorVb.Application is Nothing;iLogicVb.RuleDocument is OK;iLogicVb.Application is Nothing;
So ThisDoc.Document works, but I also need an application object to get a TranslatorAddIn
Message 5 of 8
marcin_otręba
hi,
it work for me without problem.
What version of inventor you use ?
try to change thisapplication to :
Dim ThisApp As Application = GetObject(, "Inventor.Application")
logFilePath="C:\TEMP\Log.txt"
If ThisApp Is Nothing Then
Else
	If ThisApp.ActiveDocument Is Nothing Then
	Else
Else
Else
	Else
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 6 of 8
aignatovich
I try to run it in Forge design automation service with
"Autodesk.Inventor+2021" engine. It works locally. I tried the code you suggested, but unfortunately, it doesn't work either but in a different way:
[06/19/2020 09:10:02]     InventorCoreConsole.exe Information: 0 : Performing iLogic diagnostics...
[06/19/2020 09:10:02]     InventorCoreConsole.exe Error: 0 : iLogic error
[06/19/2020 09:10:02]  Context: RuleRunning
[06/19/2020 09:10:02]  Details: System.Exception: Cannot create ActiveX component.
[06/19/2020 09:10:02]    at Microsoft.VisualBasic.Interaction.GetObject(String PathName, String Class)
[06/19/2020 09:10:02]    at ThisRule.Main()
[06/19/2020 09:10:02]    at Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
[06/19/2020 09:10:02]    at iLogic.RuleEvalContainer.ExecRuleEval(String execRule)
[06/19/2020 09:10:02]     InventorCoreConsole.exe Information: 0 : End of iLogic diagnostics...
Message 7 of 8
WCrihfield
OK. This sounds like either InventorServer or InventorApprenticeServer, I don't know why I didn't think of this sooner.
See these links, for reference info on the ILowLevelSupport Interface & the InventorServer property.
Wesley Crihfield
Message 8 of 8
aignatovich
Thanks, it works!
So, I've replaced:
Dim inventorServer = InventorVb.InventorServer ' new
Dim oDocument As Document
'oDocument = ThisApplication.ActiveDocument ->
oDocument = ThisDoc.Document
Dim oContext As TranslationContext
'oContext = ThisApplication.TransientObjects.CreateTranslationContext ->
oContext = inventorServer.TransientObjects.CreateTranslationContext
Dim oOptions As NameValueMap
'oOptions = ThisApplication.TransientObjects.CreateNameValueMap ->
oOptions = inventorServer.TransientObjects.CreateNameValueMap
Dim oDataMediumDWG As DataMedium
'oDataMediumDWG = ThisApplication.TransientObjects.CreateDataMedium ->
oDataMediumDWG = inventorServer.TransientObjects.CreateDataMedium
Hope, it would be useful for others as well
