Please try the following code:
Before trying the code, please create a part file with a block and a sketch(With a sketch point) in it, as below image shows:
Sub test()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oSk As PlanarSketch
Set oSk = oDoc.ComponentDefinition.Sketches("Sketch2")
Dim oSkPt As SketchPoint
Set oSkPt = oSk.SketchPoints(2)
Dim oObjCol As ObjectCollection
Set oObjCol = ThisApplication.TransientObjects.CreateObjectCollection
Call oObjCol.Add(oSkPt)
Dim oHoleDef As HolePlacementDefinition
Set oHoleDef = oDoc.ComponentDefinition.Features.HoleFeatures.CreateSketchPlacementDefinition(oObjCol)
Dim oHole As HoleFeature
Set oHole = oDoc.ComponentDefinition.Features.HoleFeatures.AddDrilledByThroughAllExtent(oHoleDef, 0.25, kSymmetricExtentDirection)
End Sub
Then you are supposed to get the hole feature created, as the image below:
There are many other ways to create hole feature via API, please change the code as needed.
Jane Fan
Inventor/Fusion QA Engineer
