Troubles with Sheet Metal Defaults (SheetMetalStylesCMD) in VBA
S.Hørup
S.Hørup
When we are making new IPT-files at my workplace, we use a UserForm I have made to select material and changes dimensions etc.
If a user selects a material for which have bend rules assigned, the UserForm converts the part to a sheet metal with the PartConvertToSheetMetalCmd-command:
Dim oPartToSheetMetal As ControlDefinition
Set oPartToSheetMetal = ThisApplication.CommandManager.ControlDefinitions.Item("PartConvertToSheetMetalCmd")
If odoc.DocumentSubType.DocumentSubTypeID <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then 'If the part is different from sheet metal type, then set to sheet metal oPartToSheetMetal.Execute2 (True) 'Convert to Sheet metal. This activates the Sheet Metal Defaults, and waits for user input. End If
This was all well and good in Inventor 2015. Now we  have just upgraded to Inventor 2017, and someone at Autodesk have decided that the "Sheet Metal Defaults"-command is executed when converting a part to Sheet Metal. That is not a great solution when we use VBA to all our settings.
I am trying to find a work around.
What I have come up with so far:
Dim oCMD As ControlDefinition
Set oCMD = oApp.CommandManager.ControlDefinitions("SheetMetalStylesCmd")
oCMD.Execute 'Open Sheet Metal Defaults (this interupts the "Select Base Face" user input)
SendKeys "{ESC}", True ' Close the "Sheet Metal Defaults-window"
This solution works as intended, except that the Sendkeys-command annoys every user by changing key-states on NumLock etc. And I have to run through the code twice to be sure the Sheet metal defaults are updated properly.
My question:
Is there any way to abort or disable the "Sheet Metal Defaults" from running in the first place? (regedit, xml files?)
I want it to work just as it did in Inventor 2015.
Can I abort SheetMetalDefault with VBA code (I would rather not use send keys)
S.Hørup
 As it is now, if I could reach either 'close' or 'Cancel' I could manage.
S.Hørup
Update 1:
I managed to find the following solution:
Sub CloseCommand()
    If ThisApplication.CommandManager.ActiveCommand = "SheetMetalStylesCmd" Then
        'close the command window
        ThisApplication.CommandManager.StopActiveCommand
End Sub
It works in the situation where I do the steps manually. Case scenario: I open my userform, just to have the form open. then I convert to sheet metal manually. I press "Sheet Metal Defaults" to interrupt the "Select Base Face"-selection. I then run the above code. It works flawless.
However, if i put in the above code to my user form I end up with "Select base face".......
                oPartToSheetMetal.Execute2 (False)
                ocmd.Execute
I have made a video where I show the (supposed to be) identical processes. First you se the manual way, then the proces of my form.
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Steffen,
In UserForm, update the following code to cancel "Sheet Metal Defaults" dialog.
    Set oCMD = ThisApplication.CommandManager.ControlDefinitions("SheetMetalStylesCmd")
         Dim cancleCmd As ControlDefinition
         Set cancleCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppContextual_CancelCmd")
         cancleCmd.Execute
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
S.Hørup
Hi Chandra
It works perfectly. Thanks a lot.
Kind regards, Steffen
