Inventor drawing view shift/jumble after updating model
nismo1990
nismo1990
When I make a model change then go back to the drawing and I let the drawing update it shifts/jumbles all the views around. I was wondering if anyone knows how to make it stop moving them?!?!?!?!?!?!?!?
I have changed the setting below which gives me better results but it still isn't perfect...
under Application settings, drawing tab, change "View Justification" to "Fixed" (the default is "Centered")
Also you could "attach" any detail views. Right click on the detail view box or circle and select "attach" then click on a relivent point
Hope this helps
M
nismo1990
sorry just seeing the response. the attach method does not work it still throws them all over the place. ill look into the View Justification.
bradeneuropeArthur
I had the same issue years ago.
I will give you the link.
https://forums.autodesk.com/t5/inventor-forum/drawing-view-moved/td-p/1452561
Are you using skeletal designs or frame generator?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
