Inventor Drawing Sheet - view scale
syafiqfarhan
syafiqfarhan
Is that possible to make this scale view on for the active sheet?
Dim oDrawDoc As DrawingDocument = ThisDrawing.Document
Dim oSheet As Sheet
Dim oSheets As Sheets
Dim oView As DrawingView
Dim oViews As DrawingViews
Dim oScale As Double
oScale = InputBox("Enter Desired Scale", "Scaler", "1")
oSheets = oDrawDoc.Sheets
For Each oSheet In oSheets
   oViews = oSheet.DrawingViews
   For Each oView In oViews
       If oView.ScaleFromBase = False Then
           oView.Scale = oScale
       End If
   Next
Next
A.Acheson
Here is a link to API help for ActiveSheet property and syntax. Just remove the loop through the sheets and on the active sheet loop through the views.
Dim oSheet As Sheet = oDrawDoc.ActiveSheet
End If
Next
Regards
Alan
syafiqfarhan
@A.Acheson I had tried to remove the loop but I show an error. Please share full code here, so I can check where is my mistake. Thanks!
A.Acheson
Here you go. Error were likely declarations in the wrong place. Hopefully you can check this tested one to see where it went wrong.
Dim oSheet As Sheet
oSheet = oDrawDoc.ActiveSheet
   End If
Next
Regards
Alan
syafiqfarhan
@A.Acheson This time working fine. Only 1 sheet change the scale. Thanks a lot.
