iLogic - Behaviour
iLogic - Behaviour
NachoShaw
Advisor Advisor
iLogic - Behaviour
NachoShaw
Hey
i have a need to use ilogic for the most simplest of functions-
If (LENGTH + MAX_TOL) > RAKE_HEAD Then
	LENGTH_HEAD = LENGTH
Else
	LENGTH_HEAD = RAKE_HEAD
InventorVb.DocumentUpdate()
the logic in the function works but it requires 2 model updates for it to work. This is placed in a part Base Model. I had this last week also when using a Max function for a largest value, the result was correct after 2 updates, not one......
Why is this and what do i need to do in order for the function to run and update once?
Nacho
Automation & Design Engineer
Inventor automation Programmer (C#, VB.Net / iLogic)
Furniture, Sheet Metal, Structural, Metal fab, Tradeshow, Fabrication, CNC
NachoShaw
This appeared to resolve it
iLogicVb.UpdateWhenDone = True
whats the
for then if it doesnt truly update?
thanks
Nacho
