Inventor Drawing Automation
syafiqfarhan
syafiqfarhan
Hi, I want to ask, is there any possibilities to do drawing Automation as per the workflow below:
1. Open any .idw or .dwg manually
2. Run Rules, to select .ipt files
3. Insert auto 4 view in the drawing space (top, front, right & ISO views); top, front, right in wireframe, ISO in shaded
4. direct scale the view as per wanted
Are there any possibilities for creating these rules? Since many part files need to be completed and speed up the process a bit. Thanks in advance.
CCarreiras
Check the "Sheet Format" theme, it does all that without programming.
https://help.autodesk.com/view/INVNTOR/2023/ENU/?query=sheet%20formats
CCarreiras
