Replace title block and parts list
j.wolbers-NoTech
j.wolbers-NoTech
Currently I am using the Ilogic code below to update the parts list on old drawings when they are saved or copied. The designer on the drawing is also updated when the drawing is saved.
However, I also made a few changes to the parts list style. I would like this code to also update the document styles, then remove the parts list and then add the parts list (same type!) again.
Unfortunately it won't work without removing the parts list. I tested this manually. Apparently Inventor does not update the parts list until it has been removed.
Could someone possibly help me with this?
Sub Main
	If ThisApplication.ActiveDocumentType <> DocumentTypeEnum.kDrawingDocumentObject Then
		'MsgBox("This rule '" & iLogicVb.RuleName & "' only works for Drawing Documents. Exiting.",vbOKOnly+vbCritical, "WRONG DOCUMENT TYPE")
		Exit Sub
	Dim oDDoc As DrawingDocument = ThisDrawing.Document
	Dim oDoc As Document = ThisDoc.Document
Dim oLastCreationDate as Date = oDDoc.PropertySets.Item("Design Tracking Properties").Item("Creation Time").value
'msgbox(oLastCreationDate)
'Set the oldest allowable date to leave the title block alone.
Dim oOldDate As Date = DateValue("10/05/2022")  ' this will often accept many formats that can be understood as representing a date.
Dim lValue as string = Format(Now, "dd/MM/yy")
'msgbox(lvalue)
'Comparing dates
'MsgBox("Older date compared to newer date = " & oLastCreationDate.CompareTo(oOldDate)) 'should equal 1, because oLastCreationDate is later than oOldDate
if oLastCreationDate.CompareTo(oOldDate) = -1 then
	ReplaceTB(oDDoc)
	Dim oMDoc As Document = ThisDrawing.ModelDocument
'	'drawing only
end if
	oDDoc.PropertySets.Item("Design Tracking Properties").Item("Creation Time").Value = lValue
	oDDoc.PropertySets.Item("Design Tracking Properties").Item("Designer").Value = ThisApplication.GeneralOptions.UserName
end Sub
function ReplaceTB(ByRef oDrDoc As DrawingDocument)
	Dim oSheets As Sheets = oDrDoc.Sheets
	Dim oSheet As Sheet
	Dim oTB As TitleBlock
	'Delete TitleBlock & Border from each sheet
	For Each oSheet In oSheets
		oSheet.Activate
		oSheet.TitleBlock.Delete
	Next
	'Re-Activate the first sheet again
	oSheets.Item(1).Activate
	'Attempt to delete all TitleBlockDefinitions
	Dim oTBDefs As TitleBlockDefinitions = oDrDoc.TitleBlockDefinitions
	For Each oTBDef As TitleBlockDefinition In oTBDefs
		If oTBDef.IsReferenced = False Then
			oTBDef.Delete
		'ElseIf oTBDef.IsReferenced = True Then
			'MsgBox("Title Block Def Named '" & oTBDef.Name & "' is referenced, and will not be deleted.",vbOKOnly+vbInformation, "CAN'T BE DELETED")
	Next
	'Specify the Drawing Template document to copy from
	Dim oTFN As String = "C:\WF\System Configurations\2020\Inventor\Templates\Template Notech V1.0.idw"
	Dim oTemplate As DrawingDocument = ThisApplication.Documents.Open(oTFN, False)
	Dim oNewTBDef As TitleBlockDefinition
	'Copy TitleBlockDefinition from Template to this drawing, and replace if already exists
	Dim oTemTBDefs As TitleBlockDefinitions = oTemplate.TitleBlockDefinitions
	For Each oTemTBDef As TitleBlockDefinition In oTemTBDefs
		If oTemTBDef.Name = "Notech" Then
			oNewTBDef = oTemTBDef.CopyTo(oDrDoc, True)
	Next
	'Place the new Border & Title Block on all sheets
		oSheet.Activate
		oSheet.AddTitleBlock(oNewTBDef, TitleBlockLocationEnum.kBottomRightPosition)
	Next
	oTemplate.Close(True)
	'oTemplate.ReleaseReference
End function
Kind regards,
Jeffrey
A.Acheson
If i remember correctly you should be able to just change the style of the partslist then change it back to bring in the changes you need. Maybe try it manaully before you try the code. I don't think it is necessary to delete but it has been a while so I could be wrong.
Try this post to change the style of the parts list
https://help.autodesk.com/view/INVNTOR/2021/ENU/?caas=caas/discussion/t5/Inventor-iLogic-and-VB-net-...
Regards
Alan
j.wolbers-NoTech
My knowledge of Ilogic is unfortunately too minimal to understand this.
If I manually update the style, and then switch between the different parts list, the parts list is updated. Deleting is therefore not necessary, but Inventor is apparently unable to do this in one go.
It would be nice if someone could help me with this.
Jeffrey
Curtis_Waguespack
Hi @j.wolbers-NoTech ,
This example switches the style of the first Partslist on the active sheet.
I hope this helps.
Curtis
Dim oDoc As DrawingDocument
oDoc = ThisApplication.ActiveDocument
Dim oPartsList as PartsList
oPartsList = oDoc.ActiveSheet.PartsLists(1)
oInput = InputRadioBox("Select Style", "Style1", "Style2", True, "iLogic")
If oInput = True
	oPartsList.Style = oDoc.StylesManager.PartsListStyles.Item("PartsList Style1")
Else
	oPartsList.Style = oDoc.StylesManager.PartsListStyles.Item("PartsList Style2")
