Inventor API: Publish DWF with Options
ThomasRambach
Advisor Advisor
Message 1 of 16
ThomasRambach
I'm having some trouble with the attached VBA script to publish a DWF. I'm trying to publish all sheets if it's a drawing but also include the 3DModel from the 1st sheet and do not include the structured BOM. I can't get the combination of those options to work correctly.
Public Sub PublishDWF(fFilename As String)
    ' Get the DWF translator Add-In.
    Dim DWFAddIn As TranslatorAddIn
    Set DWFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD95-2F4D-42CE-8BE0-8AEA580399E4}")
    'Set a reference to the active document (the document to be published).
    Dim oDocument As Document
    Set oDocument = ThisApplication.ActiveDocument
    Dim oContext As TranslationContext
    Set oContext = ThisApplication.TransientObjects.CreateTranslationContext
    oContext.Type = kFileBrowseIOMechanism
    ' Create a NameValueMap object
    Dim oOptions As NameValueMap
    Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap
    ' Create a DataMedium object
    Dim oDataMedium As DataMedium
    Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
    ' Check whether the translator has 'SaveCopyAs' options
    If DWFAddIn.HasSaveCopyAsOptions(oDocument, oContext, oOptions) Then
        oOptions.Value("Launch_Viewer") = 0
        ' Other options...
        oOptions.Value("Publish_All_Component_Props") = 1
        oOptions.Value("Publish_All_Physical_Props") = 1
        oOptions.Value("BOM_Structured") = 0
        'oOptions.Value("Password") = 0
        If TypeOf oDocument Is DrawingDocument Then
            ' Drawing options
            oOptions.Value("Publish_Mode") = kCustomDWFPublish
            'oOptions.Value("Publish_All_Sheets") = 1
            ' The specified sheets will be ignored if
            ' the option "Publish_All_Sheets" is True (1)
            Dim oSheets As NameValueMap
            Set oSheets = ThisApplication.TransientObjects.CreateNameValueMap
            ' Publish the first sheet AND its 3D model
            Dim oSheet1Options As NameValueMap
            Set oSheet1Options = ThisApplication.TransientObjects.CreateNameValueMap
            oSheet1Options.Add "Name", "Sheet:1"
            oSheet1Options.Add "3DModel", True
            oSheets.Value("Sheet1") = oSheet1Options
            'Set the sheet options object in the oOptions NameValueMap
            oOptions.Value("Sheets") = oSheets
    'Set the destination file name
    oDataMedium.FileName = fFilename + ".dwf"
    'Publish document.
    Call DWFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium)
End Sub
Replies (15)
Message 2 of 16
clutsa
Took me some time but I think I got it. One line was undoing your changes.
        ' Other options...
            ' Drawing options
            oOptions.Value("Publish_All_Sheets") = 1 'uncommented this
            'oOptions.Value("Sheets") = oSheets '<----This line was overwriting the changes.
    'Publish document.
End Sub
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
Message 3 of 16
ThomasRambach
@clutsa I'm still trying to figure out how that works. I commented it out but now it's not adding the model in the DWF. I basically want it to output all sheets, the 1st sheets model and an option for the BOM but not the structured BOM.
Message 4 of 16
clutsa
I'll look at this more on Monday but it would appear that something isn't working... I can get it to work properly after I manually export a dwf through the GUI. I use almost identical code and it's been working fine for years but now I wonder if it's just been using the last used GUI settings this whole time.
Message 5 of 16
ThomasRambach
@clutsa Yeah, it's strange. It's like it's ignoring something. I can't get a predicable result from what seems like a predictable change in the code.
Message 6 of 16
ThomasRambach
@clutsa I think the example in the help file is out of date according to the API. This line works:
oOptions.Value("Publish_3D_Models") = True
But I still can't get these two options to work:
oOptions.Value("BOM_Parts_Only") = False
oOptions.Value("BOM_Structured") = False
Message 7 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@ThomasRambach,
Good to know that you have found a workaround. Could you please click on "ACCEPT SOLUTION" button which is helpful to solve?
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Message 8 of 16
ThomasRambach
@chandra.shekar.g Not quite a completely working word-around yet.
Message 9 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@ThomasRambach,
Below options are supported for Assembly/presentation document.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 10 of 16
clutsa
The BOM data comes from the assy.
I seem to have this working...
    Dim oDocument As DrawingDocument
    Dim oModelDocument As Document
    Set oModelDocument = oDocument.ReferencedDocuments.Item(1) '<---this may need to change?
    PartsOnly = oModelDocument.ComponentDefinition.BOM.PartsOnlyViewEnabled
    Structured = oModelDocument.ComponentDefinition.BOM.StructuredViewEnabled
    oModelDocument.ComponentDefinition.BOM.PartsOnlyViewEnabled = False
    oModelDocument.ComponentDefinition.BOM.StructuredViewEnabled = False
    oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
        ' Other options...
        oOptions.Value("Publish_All_Component_Props") = True
        oOptions.Value("Publish_All_Physical_Props") = True
        oOptions.Value("BOM_Structured") = True
        oOptions.Value("BOM_Parts_Only") = True
            ' Drawing options
            oOptions.Value("Publish_Mode") = DWFPublishModeEnum.kCustomDWFPublish
            oOptions.Value("Publish_All_Sheets") = False
            oOptions.Value("Include_Sheet_Tables") = False
            For sheetNum = 1 To oDocument.Sheets.Count
                Dim oSheetOptions As NameValueMap
                Set oSheetOptions = ThisApplication.TransientObjects.CreateNameValueMap
                Call oSheetOptions.Add("Name", oDocument.Sheets(sheetNum).Name)
                If sheetNum = 1 Then
                    Call oSheetOptions.Add("3DModel", True)
                Else
                    Call oSheetOptions.Add("3DModel", False)
                oSheets.Value("Sheet" & sheetNum) = oSheetOptions
            Next
    'Publish document.
    oModelDocument.ComponentDefinition.BOM.PartsOnlyViewEnabled = PartsOnly 'reset
    oModelDocument.ComponentDefinition.BOM.StructuredViewEnabled = Structured 'reset
End Sub
Message 11 of 16
clutsa
@ThomasRambach Did you ever get this working for you?
Message 12 of 16
bradeneuropeArthur
@chandra.shekar.g
Could you please tell us where the list is documented.
https://forums.autodesk.com/t5/inventor-customization/inventor-api-publish-dwf-with-options/td-p/825...
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 13 of 16
ThomasRambach
@clutsa Not yet, I need to try your workaround still.
Message 14 of 16
clutsa
@bradeneuropeArthur enter "translator options" in the search help & commands
should lead you to ...
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-25D24E28-7517-4903-8AEE-123F8C71A89E
or whatever version you are on.
Message 15 of 16
chandra.shekar.g
Autodesk Support
Autodesk Support
@bradeneuropeArthur,
@clutsa is located exactly at help documentation for list of "translator options".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Message 16 of 16
ChristiPedersen
I have been using what is listed here to loop through each sheet and write it out but it always writes out the first sheet.  I can see that my loop is working correctly but it never sets the next sheet, always writes out the first.  I have condensed this for easier reading with declarations not shown.  Any input is greatly appreciated.  I tried clearing osheets and osheetoptions between each one but that failed.  Still outputs sheet 1 everytime.
oOptions.Value("Launch_Viewer") = False
oOptions.Value("Publish_All_Component_Props") = False
oOptions.Value("Publish_All_Physical_Props") = False
oOptions.Value("3DModel") = False
For ThisSHT = 1 To DrawDoc.Sheets.Count
On Error Resume Next
oSheets.Clear
oSheetOptions.Clear
Call oSheetOptions.Add("Name", oDocument.Sheets(ThisSHT).Name)
oSheets.Value("Sheet" & ThisSHT) = oSheetOptions
oDataMedium.FileName = frmPublishDWFDWG.txt2DDWFXSeparate & "\" & SheetNames(ThisSHT) & ".dwfx"
Next
