Inventor API Project All Entities Only Does Some Of Them
12:48 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Moved from reference post: Problems Importing .DXF or .DWG files into Inventor
Hi please help,
when i try to use API for this Why not project all entities, but just some? Can u help me please?
Used code:
Sub CreateImportedDWGComponentSample()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.Documents.Add(kPartDocumentObject)
Dim oCompDef As PartComponentDefinition
Set oCompDef = oDoc.ComponentDefinition
Dim oRefComponents As ReferenceComponents
Set oRefComponents = oCompDef.ReferenceComponents
' Create a ImportedComponentDefinition based on an AutoCAD file. Dim oImportedCompDef As ImportedComponentDefinition
Set oImportedCompDef = oRefComponents.ImportedComponents.CreateDefinition("C:\Temp\ACADDWG.dwg")
Dim oImportedDWGDef As ImportedDWGComponentDefinition
If oImportedCompDef.Type = kImportedDWGComponentDefinitionObject Then
Set oImportedDWGDef = oImportedCompDef
Else
End
End If
Dim oMatrix As Matrix
Set oMatrix = ThisApplication.TransientGeometry.CreateMatrix
oMatrix.SetTranslation ThisApplication.TransientGeometry.CreateVector(0, 0, 10)
oImportedDWGDef.Transformation = oMatrix
' Create the ImportedComponent
Dim oImportedComponent As ImportedComponent
Set oImportedComponent = oRefComponents.ImportedComponents.Add(oImportedDWGDef)
Dim oImportedDWGComponent As ImportedDWGComponent
If oImportedComponent.Type = kImportedDWGComponentObject Then
Set oImportedDWGComponent = oImportedComponent
Dim oSk As PlanarSketch
Set oSk = oCompDef.Sketches.Add(oCompDef.WorkPlanes(3))
' Get the DWGBlockDefinition for model space. Dim oDWGModelSpaceDef As DWGBlockDefinition
Set oDWGModelSpaceDef = oImportedDWGComponent.ModelSpaceDefinition
' Project DWG entities to planar sketch.
Dim oDWGEntity As DWGEntity
For Each oDWGEntity In oDWGModelSpaceDef.Entities
Call oSk.AddByProjectingEntity(oDWGEntity)
Next
End If
End Sub
