API - Get the Y-axis location of a surfacebody
Jef_E
Message 1 of 1
Jef_E
I would like to know the location along the Y-axis of a specified surfacebody within the part document object.
For example I have a surfacebody in the part located at +100 from centerpoint along the Y-Axis, the surfacebody height is +10 along the Y-axis.
I would like to retrieve via code the lowest point of the surface body along the Y-axis ( in this case +100 ) and the highest point ( in this case +110 ).
I was looking into the rangebox but cannot figure it out, but maybe this is not the object I should be looking at.
Any guidance would be greatly appreciated!
Please kudo if this post was helpfull
Please accept as solution if your problem was solved
Inventor 2014 SP2
Replies (0)
