Inventor addin 2026 to 2025
mateusz_baczewski
mateusz_baczewski
Is it possible to create an add-in for Inventor 2026 and run it in Inventor 2025 without any changes?
Is it enough to just change the reference to Autodesk.Inventor.Interop.dll in the .csproj file?
If you found it helpful, a "Like" would be much appreciated!
If this post solved your problem, please mark it as "Solution.".
marcin_otręba
yes, you can,  just put addin file into version independent location:  C:\ProgramData\Autodesk\Inventor Addins\,  or put seperate addin files for each inv version in version dependent location
and set inventor interop dll to be version independent:
but be aware that methods and properties added in 2026 version will not work in 2025.
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
bradeneuropeArthur
make the reference to the most lowest one found in this folder:
C:\Windows\Microsoft.NET\assembly\GAC_MSIL\Autodesk.Inventor.Interop
This way you are always sure that it works above the version selected.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
TylerWarner33
@bradeneuropeArthur Wouldn't the 'Autodesk.Inventor.Interop.dll' need to reference the lowest .NET 8 version, meaning 2025, not just the lowest version?
FYI: Inventor Versions documentation
bradeneuropeArthur
Also the framework indeed is relevant here. Most cases framework 4.5 will still work in most cases.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
hollypapp65
Just make addin for 2025 and it'll work for 2026.
My 2017 addin still work in 2026.
bradeneuropeArthur
In most cases yes.
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
