Inventor Add-in runs properly first time and need to exit and relaunch Inventor to run it again
J_Dumont
J_Dumont
I have an add-in that works very well but after I close the form I cannot run the program again. I need to close Inventor and relaunch. Is there a method to stop or end the program?
here is the code that closes the form.
 Private Sub BtnCancel_Click(sender As Object, e As EventArgs) Handles BtnCancel.Click
    If BtnCancel.Text = "Close" Then
      oForm.Dispose()
      Process.Start("explorer.exe", PDFFolderName)
    Else
      oForm.Dispose()
End Sub
bradeneuropeArthur
How is the form declared?
Please share the complete code.
Form.hide will maybe be better in this case. Let me figure out when I have the code.
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
J_Dumont
Hi Arthur,
Too much code to copy and paste but below shows how I define, load and close.
I hope this helps.
The form is declared in Module1
Module Module1
    Public oDocCount As String 'Get total occurance for use in Progress Bar
    Public designTrackPropSet As Inventor.PropertySet
    Public oForm As New BOMtoPDF
The form is displayed from commandfunstions.vb
Public Sub BOMtoPDFFunction()
    AppSettingsRead() 'Get configuration settings from app.config xml file
    oForm.ShowDialog()
    oForm.Visible = True
The form is closed in BOMtoPDF.vb
    oForm.Dispose()
    Else
    oForm.Dispose()
End Sub
Michael.Navara
Don't use oFom.Dispose() in button click handler use oForm.Close() instead. Once you dispose the form, you need to create new instance of them. In this case you can't declare the form using  Public oForm As New BOMtoPDF
I don't know how you start the method Public Sub BOMtoPDFFunction(), but I recommend you to create new instance of form in this method.
Method oForm.ShowDialog() display the form to the user and wait until user closes the form. Next call oForm.Visible = True is called to disposed form. In this case it has no effect or fail.
 Here is modified pseudo-code how to do it
    Dim oForm = New BOMtoPDF
    If oForm.ShowDialog() = DialogResult.OK Then
        'Open PDF Folder
        Process.Start("explorer.exe", oForm.PDFFolderName)
    Else
        'Exit Sub or something
End Sub
Sub AppSettingsRead()
End Sub
Class BOMtoPDF
    Inherits Form
    Private WithEvents BtnCancel As Button
    Public PDFFolderName As String
            DialogResult = DialogResult.OK
        Else
            DialogResult = DialogResult.Cancel
        Close()
    End Sub
End Class
