Inventor 2025.2 iLogic rule only runs when regenrating after a component replacement
3DAli
3DAli
I have a simple rule that only activates or deactivates a component based on the value of a parameter and it works fine. However, when replacing a component with a new one and replacing the names in the code, it won't run anymore unless you always regenerate the rule. Is this a bug?
Select Case Stiffener_Option
Case Is = "Top"
	Component.IsActive("Stiffener:2") = False
	Component.IsActive("Stiffener Pattern Left") = False
	Component.IsActive("Stiffener Pattern Top") = True
	Component.IsActive("Stiffener:1") = True
Case Is = "Left"
	Component.IsActive("Stiffener:1") = False
	Component.IsActive("Stiffener Pattern Top") = False
	Component.IsActive("Stiffener Pattern Left") = True
	Component.IsActive("Stiffener:2") = True
Case Is = "None"
End Select
iLogicVb.UpdateWhenDone = True
bradeneuropeArthur
To my opinion everything works ok here.
I am on Inventor 2025 with no updates build 126
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
