Inventor 2019 will rotate view when creating new part
DarioVilla5508
DarioVilla5508
Hello, I am having some issues with inventor 2019 when creating a new part. The view will rotate automatically ignoring the selected option. Does anyone have the same problem? Thank you in advance.
bradeneuropeArthur
Do you mean that the view is rotated when selecting a workplane with the sketch to be created on?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
hi
is the issue solved?
DarioVilla5508
Hi, no, it hasn't been solved. I 'm waiting for a reply from the Autodesk support team:
http://knowledge.autodesk.com/article/Dimensions-get-moved-after-bolted-connection-update-in-Invento...
Thanks anyway.
