Inventor 2014 is not compatible with Windows 10
Message 1 of 15
i installed windows 10 last week and my inventor 2014 does not work with it kept giving error.
On the same computer and before installing windows 10 i had the same ver. of Inventor 2014 (actually the same copy) worked fine with windows 8.
Any ideas on how to overcome this problem?
Replies (14)
Message 2 of 15
lynn_zhang
Hi @Anonymous Welcome to Autodesk Community!
Windows 10 has not been tested to be compatible with Inventor 2014. Please check System requirements for Autodesk Inventor 2014 products. Yes, Inventor 2014 is supported on Windows 8 but might not be supported on Windows 10.
Lynn Zhang
Message 3 of 15
Thx for the reply.
that means i will not be able to use inventor at all just because i have windows 10 , because none of the inventor products have been tested with windows 10 yet.
Message 4 of 15
I just installed windows 10 and it is NOT working with Inventor 2014.
Error: 0xC0000142
Message 5 of 15
same problem
Message 6 of 15
Sing in, open up download finder and install service pack 1 for inventor-products.
That worked with me.
Good luck.
@Anonymous wrote:
same problem
Message 7 of 15
H.O.Claussen, could you be more specific please?
I went to Autodesk, logged in, found the product updates HERE.
Under Inventor/Downloads, I don't see any "Service Packs".  A bunch of foreign languages is all I see.
I ran the installer for the 64 bit version again, but there were no changes to apply.
I'm not Inventing.
Any other tips please?
Message 8 of 15
Ah, I found the Download Finder on the knowledge home page.
That location does list SP1 Update 7 for Inventor 2014 to fix a startup issue on Windows 8.1 that is identical as the one I had on Windows 10.
Downloaded, installed, rebooted and running fine again.
THANKS!
Message 9 of 15
Welcome, happy that in the end it was helpful.
Message 10 of 15
Sp1 update 7 thats working ! Thx
Message 11 of 15
Message 12 of 15
Thank You very much! I have tried so many fixes that didn't work. Your solution was easy and, it fixed the problem.
Message 13 of 15
I install service pack 1 and 2 use win 10 pro 64bit and now it works.
Message 14 of 15
is there any Path file available to run this.
Message 15 of 15
install Sp1 update 7
