Create visibility states for same feature found throughout all parts in assembly
I need help with turning on and off a common feature found in every part I have in any given assembly.  I've tried using Levels of Detail and Views, but I get the impression that those options are only available for parts, not the features in those parts.  True or not?
More specifically...I have conveyor beds as parts that have a feature in them called Control_Side_Crossover.  In any given project. some of the beds have this feature switched on, some have it off.  I need a way to globally shut them all off (for BOM export purposes) and then return them to their previous state.  I had kinda the same question a while ago, but that was for globally shutting off a feature that was completely either globally on/off.
Again...this time, I need to capture the "visibility" state of a different component, globally turn them all off, then all-at-once restore the select few that were previously turned on.
Thanks in advance for any help!
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi @Anonymous,
Hope below sample iLogic rule can help to turn on / off specific Feature. It is tested with attached assembly file.
In this example, iLogic rule would turn on / off of Hole Feature.
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
Dim featName As String = "Hole"
Dim oDef As AssemblyComponentDefinition
oDef = oDoc.ComponentDefinition
For Each occ As ComponentOccurrence In oDef.Occurrences
    If occ.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
        Dim partDef As PartComponentDefinition
        partDef = occ.Definition
        For Each oFeature As PartFeature In partDef.Features
            If oFeature.Name.StartsWith(featName) Then
                If oFeature.Suppressed = True Then
                    oFeature.Suppressed = False
                Else
        Next
Next
InventorVb.DocumentUpdate()
Refer the following link for more details on iLogic.
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-C5ADE109-10E9-41A0-BC4A-BE73AA68A1C7
Please feel free to contact if there is any doubt.
If solves problem, click on "Accept as solution" / give a "Kudo".
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
