Inventor 2014 API How to change part color?
I've been trying to change a parts color for three days.
I've seen in an example, that you can use "RenderStyle" of the "ComponentOccurrence" class.
But the "ComponentOccurence"-class doesn't have this property any longer (Inventor 2014 API).
Does anybody know, which property or class I can use instead of?
If you are trying to change part color in Assembly document try the below code (vb.net)
 If m_inventorApplication.ActiveDocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then Exit Sub
            Try
                Dim oAssyDoc As Inventor.AssemblyDocument
                oAssyDoc = m_inventorApplication.ActiveDocument
                Dim oOccurrences As Inventor.ObjectCollection
                oOccurrences = m_inventorApplication.TransientObjects.CreateObjectCollection
                Dim oPartOcc As Inventor.ComponentOccurrence
                For Each oPartOcc In oAssyDoc.SelectSet
                    oOccurrences.Add(oPartOcc)
                Next
                Dim oRsAssy As Inventor.RenderStyle
                oRsAssy = oAssyDoc.RenderStyles.Item("Red")
                For Each oPartOcc In oOccurrences
                    oPartOcc.SetRenderStyle(StyleSourceTypeEnum.kOverrideRenderStyle, oRsAssy)
                Next
            Catch ex As Exception
                MsgBox(ex.Message)
            End Try
 if inside part document itself try this
If m_inventorApplication.ActiveDocumentType <> DocumentTypeEnum.kPartDocumentObject Then Exit Sub
            Try
                Dim oPartDoc As Inventor.PartDocument
                oPartDoc = m_inventorApplication.ActiveDocument
                Dim oPartFeature As Object
                'Inventor.PartFeature
                For Each oPartFeature In oPartDoc.SelectSet
                    oOccurrences.Add(oPartFeature)
                Next
                Dim oRs As Inventor.RenderStyle
                oRs = oPartDoc.RenderStyles.Item("Red")
                For Each oPartFeature In oOccurrences
                    oPartFeature.SetRenderStyle(StyleSourceTypeEnum.kOverrideRenderStyle, oRs)
                Next
                MsgBox(ex.Message)
            End Try
 you can convert the same to vba also.
Inventor 2014 API method is different than the above and see the below code from API Help
Public Sub SetOccurrenceAppearance()
    Dim asmDoc As AssemblyDocument
    Set asmDoc = ThisApplication.ActiveDocument
    ' Get an appearance from the document.  To assign an appearance is must
    ' exist in the document.  This looks for a local appearance and if that
    ' fails it copies the appearance from a library to the document.
    Dim localAsset As Asset
    On Error Resume Next
    Set localAsset = asmDoc.Assets.Item("Bamboo")
    If Err Then
        On Error GoTo 0
        ' Failed to get the appearance in the document, so import it.
        ' Get an asset library by name.  Either the displayed name (which
        ' can changed based on the current language) or the internal name
        ' (which is always the same) can be used.
        Dim assetLib As AssetLibrary
        Set assetLib = ThisApplication.AssetLibraries.Item("Autodesk Appearance Library")
        'Set assetLib = ThisApplication.AssetLibraries.Item("314DE259-5443-4621-BFBD-1730C6CC9AE9")
        ' Get an asset in the library.  Again, either the displayed name or the internal
        ' name can be used.
        Dim libAsset As Asset
        Set libAsset = assetLib.AppearanceAssets.Item("Bamboo")
        'Set libAsset = assetLib.AppearanceAssets.Item("ACADGen-082")
        ' Copy the asset locally.
        Set localAsset = libAsset.CopyTo(asmDoc)
    End If
    On Error GoTo 0
    ' Have an occurrence selected.
    Dim occ As ComponentOccurrence
    Set occ = ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select an occurrence.")
    ' Assign the asset to the occurrence.
    occ.appearance = localAsset
End Sub
Thank you for your help.
I've already tried this example in the API help.
Unfortunately, the code doesn't work.
I've no access to the "Item"-Property in asmDoc.Assets.Item("...");
I use C#.
xiaodong_liang
Autodesk Support
Autodesk Support
the syntax of C# is not always the same as VB.NET. To get an item of an array, normally, in C#, it could be
    asmDoc.Assets[name, e.g. "XXX"]
    asmDoc.Assets[index. e.g. 1,2,3...]
    or, sometimes the library of API may provides such as
    Array.get_Item("XXX")
    Array.get_Item(1)
in VB.NET, normally it could be:
  asmDoc.Assets(name, e.g. "XXX")
    asmDoc.Assets(index. e.g. 1,2,3...)
    Array.Item("XXX")
    Array.Item(1)
Now I can use the "Items"-property.
Unforunately, I can't set the "Appearance"-property of the "ComponentOccurancy"-class.
Visual Studio says, that this property is read only.
(asmDoc is the active assembly document and compocc is the componentOccurence of the selected part)
Asset localAsset = asmDoc.Assets["Holz (Kirsche)"];
//the following line doesn't work
compOcc.Appearance = localAsset;
