Creating ilogic Assembly with Standard components
09:17 PM
Hi
Long time Autocad user but now am moving most of my work across to Autodesk Inventor.
Some of the work I do is with companies that their parts are standard components that will not change.
So I am using Inventor to automate the drawings based on their requirements. For example if it needs to be 4m high. then to use 2 x 2m sections. Currently I have create different assemblies of the different potential heights that I can switch between using ilogic but I need to be able to shift the top truss arch depending on how high the truss is.
Any links to any previous discussions like this would be helpful. It's basically automatting lego
