Inventor 2008 LeaderNote.FormattedText
Hello to all,
I have a question about the public property FormattedText in the Inventor.LeaderNote object. I am wanting to include a named model parameter to a LeaderNote within a DrawingDocument. The API help document says that to insert an XML tag that i can not seem to get to work. Or to post on this message since it is XML.
When I set this to my LeaderNote object it will create the note but the text will be what is above. I searched the discussion groups and did find how to add FormatedText to a LeaderNote. Is this a bug with LeaderNotes or is my XML tag not legal for Inventor to read? Is there a way to include a model or user parameter in a LeaderNote programmatically in Inventor 2008?
Thank you in advance.
Unfortunately, the implementation of this property is very sensitive to the
upper/lower cases of the XML tags. And I think that the help document has
some errors as well. Here is some code to help you with this. This should
append the value of a parameter "d0" from the model document
("C:\temp\block.ipt")
Sub FormatText()
Dim oDoc As Document
Set oDoc = ThisApplication.ActiveDocument
Dim oLeaderNote As LeaderNote
Set oLeaderNote = oDoc.SelectSet(1)
oLeaderNote.FormattedText = oLeaderNote.FormattedText & "
ComponentIdentifier='C:\temp\block.ipt' Name='d0'
Precision='2'>
End Sub
Sanjay-
wrote in message news:5627128@discussion.autodesk.com...
Hello to all,
Sanjay,
Thank you for the quick response. The XML tags are very case sensitive. I changed the p in parameter and the n in name to uppercase and removed the double quotation. Works great!
Thank you again Sanjay for your time,
Lucas
I have another question about LeaderNote objects. After obtaining the parameters form the model onto the drawing I want to change the Unit Attribute to suppress the LeadingZeroDisplay. I have tried to use the DimensionStyle.LeaderingZeroDisplay set equal to false but it doesn't seem to work. The dialog box that appears when you RMB the LeaderNote says Edit Unit Attribute. Not sure if this is even possible yet for 2008 release.
Thank you in advance,
Lucas
The 'Edit Unit Attributes' options are not currently available thru the API.
Sanjay-
wrote in message news:5628386@discussion.autodesk.com...
Lucas
