Friday Brain Fade and error checking loops
Hi guys
having a case of friday brain fade and i can't for the life of me figure out this problem.
Below is my code for creating the dxf from a flat pattern and it works just great. The issue is that on our title blocks we like to have a text box that lists the dxf filename path and revision. This also works great.... the first time. The problem i have is when i subsequently run the code ie rev 2 3 etc the dxf is created with the correct revision number but the custom text field isn't getting updated and i think it has something to do dwith the error loop check at the bottom end of the code. The error check is a simple way (or i thought so at the time) to stop the routine from crashing if the custom iproperty dxf_filename isn't already defined.
Look forward to any / all input on this.
thanks
daren
M90 84.29 4GB Win XPsp2 Inventor 2008Pro
Public Sub DXFOUT()
'Check for Sheetmetal File
If ThisApplication.ActiveDocument.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox "Unable to extract DXF file from this file. Only works for Sheet Metal File types."
End
'Define Variables
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oPropSets As PropertySets
Set oPropSets = oDoc.PropertySets
Dim oPropSet As PropertySet
Dim oProp As Property
'Define DataIO
Dim oDataIO As DataIO
Set oDataIO = oDoc.ComponentDefinition.DataIO
Dim oOut As String
oOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=0&InteriorProfilesLayer=0"
'Collect iProperties to define file name
Set oPropSet = oPropSets.Item("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}")
Dim oREVNumber As String
oREVNumber = oPropSet.ItemByPropId(kRevisionSummaryInformation).Value
Set oPropSet = oPropSets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")
Dim oPartNumber As String
oPartNumber = oPropSet.ItemByPropId(kPartNumberDesignTrackingProperties).Value
'Dim oFileNameLength As String
'oFileNameLength = Len(ThisApplication.ActiveDocument.DisplayName)
'Set dxf File Location
Dim oPathName As String
'oPathName = Left(oDoc.FullFileName, Len(oDoc.FullFileName) - oFileNameLength)
oPathName = "c:/punching files/"
'Set dxf File Name
Dim oDXFName As String
If oREVNumber < 10 Then
oDXFName = oPathName & oPartNumber & "B0" & oREVNumber & ".dxf"
Else
oDXFName = oPathName & oPartNumber & "B" & oREVNumber & ".dxf"
'Write dxf File out
oDataIO.WriteDataToFile oOut, oDXFName
'Check for and define or set custom iproperty for use on title block
Dim oCustomPropset As PropertySet
Set oCustomPropset = oPropSets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
On Error Resume Next
Err.Clear
Check = oCustomPropset.Item(dxf_filename).Value
If Err.Number <> 0 Then
'Adding the new Property to the CustomPropertySet
Call oCustomPropset.Add(oDXFName, "dxf_filename")
Else
ThisApplication.ActiveDocument.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("dxf_filename").Value = oDXFName
Err.Clear
On Error GoTo 0
End Sub
Change the following line:
to
Check = oCustomPropset.Item("dxf_filename").Value
Sanjay-
wrote in message news:5627207@discussion.autodesk.com...
Hi guys
this problem.
thanks
daren
Public Sub DXFOUT()
Metal File types."
End
'Define Variables
'Define DataIO
Dim oOut As String
oPartNumber =
oFileNameLength)
'Set dxf File Name
Else
'Write dxf File out
Err.Clear
Else
= oDXFName
Err.Clear
On Error GoTo 0
End Sub
Sanjay
Many thanks that has solved my problem. I think it was a case of not seeing the forest for the trees.
thanks
daren
