Friday Brain Fade and error checking loops
07:51 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi guys
having a case of friday brain fade and i can't for the life of me figure out this problem.
Below is my code for creating the dxf from a flat pattern and it works just great. The issue is that on our title blocks we like to have a text box that lists the dxf filename path and revision. This also works great.... the first time. The problem i have is when i subsequently run the code ie rev 2 3 etc the dxf is created with the correct revision number but the custom text field isn't getting updated and i think it has something to do dwith the error loop check at the bottom end of the code. The error check is a simple way (or i thought so at the time) to stop the routine from crashing if the custom iproperty dxf_filename isn't already defined.
Look forward to any / all input on this.
thanks
daren
M90 84.29 4GB Win XPsp2 Inventor 2008Pro
Public Sub DXFOUT()
'Check for Sheetmetal File
If ThisApplication.ActiveDocument.SubType <> "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}" Then
MsgBox "Unable to extract DXF file from this file. Only works for Sheet Metal File types."
End
End If
'Define Variables
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oPropSets As PropertySets
Set oPropSets = oDoc.PropertySets
Dim oPropSet As PropertySet
Dim oProp As Property
'Define DataIO
Dim oDataIO As DataIO
Set oDataIO = oDoc.ComponentDefinition.DataIO
Dim oOut As String
oOut = "FLAT PATTERN DXF?AcadVersion=2004&OuterProfileLayer=0&InteriorProfilesLayer=0"
'Collect iProperties to define file name
Set oPropSet = oPropSets.Item("{F29F85E0-4FF9-1068-AB91-08002B27B3D9}")
Dim oREVNumber As String
oREVNumber = oPropSet.ItemByPropId(kRevisionSummaryInformation).Value
Set oPropSet = oPropSets.Item("{32853F0F-3444-11D1-9E93-0060B03C1CA6}")
Dim oPartNumber As String
oPartNumber = oPropSet.ItemByPropId(kPartNumberDesignTrackingProperties).Value
'Dim oFileNameLength As String
'oFileNameLength = Len(ThisApplication.ActiveDocument.DisplayName)
'Set dxf File Location
Dim oPathName As String
'oPathName = Left(oDoc.FullFileName, Len(oDoc.FullFileName) - oFileNameLength)
oPathName = "c:/punching files/"
'Set dxf File Name
Dim oDXFName As String
If oREVNumber < 10 Then
oDXFName = oPathName & oPartNumber & "B0" & oREVNumber & ".dxf"
Else
oDXFName = oPathName & oPartNumber & "B" & oREVNumber & ".dxf"
End If
'Write dxf File out
oDataIO.WriteDataToFile oOut, oDXFName
'Check for and define or set custom iproperty for use on title block
Dim oCustomPropset As PropertySet
Set oCustomPropset = oPropSets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
On Error Resume Next
Err.Clear
Check = oCustomPropset.Item(dxf_filename).Value
If Err.Number <> 0 Then
'Adding the new Property to the CustomPropertySet
Call oCustomPropset.Add(oDXFName, "dxf_filename")
Else
ThisApplication.ActiveDocument.PropertySets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}").Item("dxf_filename").Value = oDXFName
Err.Clear
End If
On Error GoTo 0
End Sub
thanks
daren
Public Sub DXFOUT()
End
End If
'Define Variables
'Define DataIO
Dim oOut As String
'Set dxf File Name
Else
End If
'Write dxf File out
Err.Clear
Else
Err.Clear
End If
On Error GoTo 0
End Sub
