INV2014: Beading Punchtool Flat Pattern
mario170979
mario170979
Attached a picture of a beading we would like to use for production of sheet metal. For programming of our machines (Truamatic Punch) we need in the exported DWG a line for the placement which shows the lengt and position. To place a beading with the punch tool we have a solution problems:
- Placing only on a center point. Would be better to draw a line and than the punchtool registrate: angle and length for placing of the beading. this is not so importand but more work for us actual and can generate mistakes.
- Flat pattern is the biggest problem. Because on the Flat Pattern we see the 3D form of the beading. A changing of "Punch Representation" to "2D Sketch Representation" helps not.
Maybe somebody have a solution which is working and helps in one of the steps.
MR
Autodesk Inventor Professional 2025
Autodesk Vault Professional 2025
HermJan.Otterman
when making the Punchtool, did you create/select a sketch, that will be shown if you choose "Sketch representation"..??
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
