INV2014: Beading Punchtool Flat Pattern
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Attached a picture of a beading we would like to use for production of sheet metal. For programming of our machines (Truamatic Punch) we need in the exported DWG a line for the placement which shows the lengt and position. To place a beading with the punch tool we have a solution problems:
- Placing only on a center point. Would be better to draw a line and than the punchtool registrate: angle and length for placing of the beading. this is not so importand but more work for us actual and can generate mistakes.
- Flat pattern is the biggest problem. Because on the Flat Pattern we see the 3D form of the beading. A changing of "Punch Representation" to "2D Sketch Representation" helps not.
Maybe somebody have a solution which is working and helps in one of the steps.
Autodesk Inventor Professional 2025
Autodesk Vault Professional 2025
