IntersectWithSurface method
basnederveen
basnederveen
I'm trying to see if a linesegment intersects a surfacebody, but I keep getting a Run time error (Method 'IntersectWithSurface' of object 'LineSegment' failed)
This is the code:
Private Function cableClash(p1 As Point, p2 As Point) As Boolean
    ' Create a linesegment
    Dim l As LineSegment
    Set l = ThisApplication.TransientGeometry.CreateLineSegment(p1, p2)
    ' Set part in which the surface is
    Dim str As String: str = "C:\Workspace\Documents\Projects\2018\TWD-NL-2018-066\REFERENCES\VESSEL OUTLINE_TWD20180507145730678.ipt"
    Dim prt As PartDocument
    Set prt = ThisApplication.Documents.Open(str, False)
    ' Set the surface
    Dim surf As Object
    Set surf = prt.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1).SurfaceBodies.Item(1).SurfaceBodies.Item(1)
   ' On Error Resume Next
    Dim out As ObjectsEnumerator
    Set out = l.IntersectWithSurface(surf)
End Function
I've also tried to just say
    If l.IntersectWithSurface(surf).Count <> 0 Then
All give the same runtime error..
How do I get this method to work?
basnederveen
Found it already. You cannot use surfacebodies, only
LineSegment.IntersectWithSurface Method
Input object. This can be a Plane, Cone, Cylinder, EllipticalCone, EllipticalCylinder, Sphere, Torus or a BSplineSurface.
