- Mute
- Permalink
- Report
I'm trying to see if a linesegment intersects a surfacebody, but I keep getting a Run time error (Method 'IntersectWithSurface' of object 'LineSegment' failed)
This is the code:
Private Function cableClash(p1 As Point, p2 As Point) As Boolean
' Create a linesegment
Dim l As LineSegment
Set l = ThisApplication.TransientGeometry.CreateLineSegment(p1, p2)
' Set part in which the surface is
Dim str As String: str = "C:\Workspace\Documents\Projects\2018\TWD-NL-2018-066\REFERENCES\VESSEL OUTLINE_TWD20180507145730678.ipt"
Dim prt As PartDocument
Set prt = ThisApplication.Documents.Open(str, False)
' Set the surface
Dim surf As Object
Set surf = prt.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Item(1).SurfaceBodies.Item(1).SurfaceBodies.Item(1)
' On Error Resume Next
Dim out As ObjectsEnumerator
Set out = l.IntersectWithSurface(surf)
End FunctionI've also tried to just say
If l.IntersectWithSurface(surf).Count <> 0 Then
All give the same runtime error..
How do I get this method to work?
