INSPECTION TABLE
INSPECTION TABLE
37xitp4
INSPECTION TABLE
37xitp4
I have work on this code to generate the inspection dimension into a custom table.
I have an issue to get the tolerance value based on "ToleranceTypeEnum Enumerator"
I have set it using case statement but still can't get the correct value
Public Sub InchInspectionTable()
'SET A REFERENCE TO THE ACTIVATE DRAWING
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
'SET REFERENCE TO THE ACTIVATE SHEET
    Dim oSheet As Sheet
    Set oSheet = oDrawDoc.ActiveSheet
'REMOVE EXISTING CUSTOM TABLE
    If oSheet.CustomTables.Count > 0 Then
    oSheet.CustomTables.Item(1).Delete
    End If
'CREATE CUSTOM TABLE
    Dim CustomTableTitle As String
    CustomTableTitle = "INSPECTION DIMENSIONS" 'Set the Table title
    Dim oTitles(1 To 4) As String 'set number of column
    oTitles(1) = "INSPECTION LABEL" 'Set the table header 1
    oTitles(2) = "DESIGNED DIMENSION" 'Set the table header 2
    oTitles(3) = "UPPER TOLERANCE" 'Set the table header 3
    oTitles(4) = "LOWER TOLERANCE" 'Set the table header 4
    Dim InsP As Point2d
    Set InsP = ThisApplication.TransientGeometry.CreatePoint2d(15, 15)
    oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.HeadingGap = 0.125
    oDrawDoc.StylesManager.ActiveStandardStyle.ActiveObjectDefaults.TableStyle.ColumnValueHorizontalJustification = kAlignTextCenter
    Dim oGenDimCount As Integer
    oGenDimCount = 0
    Dim oDim As DrawingDimension
    For Each oDim In oSheet.DrawingDimensions
        If oDim.IsInspectionDimension Then
            oGenDimCount = oGenDimCount + 1
        End If
    Next
    Debug.Print "Inspection Dims Count = " + CStr(oGenDimCount)
    Debug.Print "Drawing Dims Count = " + CStr(oSheet.DrawingDimensions.Count)
    Dim oCustomTable As CustomTable
    Set oInspDimTable = oSheet.CustomTables.Add(CustomTableTitle, InsP, 4, oGenDimCount, oTitles)
'SET THE VALUE OF THE TABLE
    Dim oInspDimShape As InspectionDimensionShapeEnum
    Dim oDesignedDimension As Variant
    Dim oAngularDesignedDimension As Variant
    Dim oInspDimNumber As String
    Dim oInspDimRate As String
    Dim i As Integer
    Dim oCellInspDimNum As Cell
    Dim oCellInspDim As Cell
    Dim oCellInspUpTol As Cell
    Dim oCellInspLowTol As Cell
    i = 1
        If oDim.IsInspectionDimension And oDim.Type = 117474560 Or oDim.IsInspectionDimension And oDim.Type = 117475072 Or oDim.IsInspectionDimension And oDim.Type = 117475328 Then 'Linier Dimension
            oDim.GetInspectionDimensionData oInspDimShape, oInspDimNumber, oInspDimRate
            oDesignedDimension = ThisApplication.UnitsOfMeasure.GetStringFromValue(oDim.ModelValue, 11272)
            Debug.Print oInspDimNumber
            Debug.Print oDesignedDimension
            Debug.Print "Tolerance type = " + CStr(oDim.Tolerance.ToleranceType)
            Debug.Print "Tolerance Upper = " + CStr(oDim.Tolerance.Upper)
            Debug.Print "Tolerance Lower = " + CStr(oDim.Tolerance.Lower)
            Debug.Print "Tolerance Precision = " + CStr(oDim.TolerancePrecision)
            Debug.Print ""
            Set oCellInspDimNum = oInspDimTable.Rows.Item(i).Item("INSPECTION LABEL")
            oCellInspDimNum.Value = oInspDimNumber
            Set oCellInspDim = oInspDimTable.Rows.Item(i).Item("DESIGNED DIMENSION")
            oCellInspDim.Value = oDesignedDimension
                Select Case Tolerance
                    Case Is = oDim.Tolerance.ToleranceType = 31236 'Deviation Tolerance
                        Set oCellInspUpTol = oInspDimTable.Rows.Item(i).Item("UPPER TOLERANCE")
                        oCellInspUpTol.Value = "A"
                        Set oCellInspLowTol = oInspDimTable.Rows.Item(i).Item("LOWER TOLERANCE")
                        oCellInspLowTol.Value = "B"
                    Case Is = oDim.Tolerance.ToleranceType = 31238 'Limit Linear Tolerance
                        oCellInspUpTol.Value = "C"
                        oCellInspLowTol.Value = "D"
                    Case Is = oDim.Tolerance.ToleranceType = 31242  'Limits/Fits-Linear Tolerance
                        oCellInspUpTol.Value = "E"
                        oCellInspLowTol.Value = "F"
                    Case Is = oDim.Tolerance.ToleranceType = 31243 'Limits/Fits-Show Size Tolerance
                        oCellInspUpTol.Value = "G"
                        oCellInspLowTol.Value = "H"
                    Case Is = oDim.Tolerance.ToleranceType = 31244  'Limits/Fits-Show Tolerance
                        oCellInspUpTol.Value = "I"
                        oCellInspLowTol.Value = "J"
                    Case Is = oDim.Tolerance.ToleranceType = 31241 'Limits/Fits-Stacked Tolerance
                        oCellInspUpTol.Value = "K"
                        oCellInspLowTol.Value = "L"
                    Case Is = oDim.Tolerance.ToleranceType = 31237 'Limits-Stacked Tolerance
                        oCellInspUpTol.Value = "M"
                        oCellInspLowTol.Value = "N"
                    Case Is = oDim.Tolerance.ToleranceType = 31239 'MAX Tolerance
                        oCellInspUpTol.Value = "O"
                        oCellInspLowTol.Value = "P"
                    Case Is = oDim.Tolerance.ToleranceType = 31240 'MIN Tolerance
                        oCellInspUpTol.Value = "Q"
                        oCellInspLowTol.Value = "R"
                    Case Is = oDim.Tolerance.ToleranceType = 31235 'Symmetric Tolerance
                        oCellInspUpTol.Value = "S"
                        oCellInspLowTol.Value = "T"
                    End Select
            i = i + 1
        End If
    Next
    oInspDimTable.Sort "INSPECTION LABEL", True
    Dim oRow As Row
    For Each oRow In oInspDimTable.Rows
        If oCellInspDimNum.Value <> oInspDimNumber Then
            oRow.Delete
        End If
    Next
End Sub
dgreatice
updated you code:
Dim oSheet As Sheet
End If
Dim InsP As Point2d
oGenDimCount = 0
End If
Next
Dim i As Integer
i = 1
Debug.Print ""
Select Case oDim.Tolerance.ToleranceType
Case kDeviationTolerance 'Deviation Tolerance
Case kLimitLinearTolerance 'Limit Linear Tolerance
Case kLimitsFitsLinearTolerance 'Limits/Fits-Linear Tolerance
Case kLimitsFitsShowSizeTolerance 'Limits/Fits-Show Size Tolerance
Case kLimitsFitsShowTolerance 'Limits/Fits-Show Tolerance
Case kLimitsFitsStackedTolerance 'Limits/Fits-Stacked Tolerance
Case kLimitsStackedTolerance 'Limits-Stacked Tolerance
Case kMaxTolerance 'MAX Tolerance
Case kMinTolerance 'MIN Tolerance
Case kSymmetricTolerance 'Symmetric Tolerance
End Select
i = i + 1
End If
Next
Dim oRow As Row
oRow.Delete
End If
Next
End Sub
Please use the ACCEPT AS SOLUTION or KUDOS button if my Idea helped you to solve the problem.
Autodesk Inventor Professional Certified 2014
rom.poteaux4DZ5Y
Why would i get the Sub Main() error?
i'm in inventor 2023 and in text file for my external rules.
