Insert specific size fastener from Content Center using VB.NET
J_Dumont
Message 1 of 10
J_Dumont
I am trying to insert a fastener from Content Center, and the conditions will determine the size that is needed.
I was able to use the code in the API help to place all members of a family but I need to narrow that down.
    Public Sub InsertPEMNuts()
        'Dim oAsmDoc As AssemblyDocument
        'oAsmDoc = ThisApplication.ActiveDocument
        Dim oContentCenter As ContentCenter
        oContentCenter = g_inventorApplication.ContentCenter
        Dim oContentNode As ContentTreeViewNode
        oContentNode = oContentCenter.TreeViewTopNode.ChildNodes.Item("Fasteners").ChildNodes.Item("Bolts").ChildNodes.Item("Hex Head")
        Dim oFamily As ContentFamily
        For Each oFamily In oContentNode.Families
            If oFamily.DisplayName = "ISO 4015" Then
                Exit For
            End If
        Next
        ' Create a NameValueMap to specify parameters (e.g., length, diameter)
        Dim oParams As NameValueMap
        oParams = g_inventorApplication.TransientObjects.CreateNameValueMap
        oParams.Add("NND", 5) ' Set length to 50 mm
        oParams.Add("NLG", 35)
        ' Create the member
        Dim failureReason As MemberManagerErrorsEnum
        Dim failureMessage As String
        Dim oMemberDoc As Document
        oMemberDoc = oFamily.CreateMember(oParams, failureReason, failureMessage, ContentMemberRefreshEnum.kRefreshOutOfDateParts)
        ' Insert the member into the assembly
        Dim oMatrix As Matrix
        oMatrix = g_inventorApplication.TransientGeometry.CreateMatrix
        Dim oOcc As ComponentOccurrence
        oOcc = oDoc.ComponentDefinition.Occurrences.Add(oMemberDoc.FullFileName, oMatrix)
    End Sub
It seems that I need to specify the row. I don't know how to determine the row from the information that I have.
Here's my error.
Replies (9)
Message 2 of 10
jjstr8
You're correct that you need to specify a row (or ContentIdentifier string) when calling .CreateMember. I'm not seeing anything built in to narrow it down to your NND & NLG values through the ContentFamily type. It looks like you'll have to loop through oFamily.TableRows and look for a match. Fortunately, you don't have to loop through all columns. The indexer in TableRow does takes a column name string, i.e. oFamily.TableRows(1).Item("NND") will return the column with its InternalName  = "NND".
Message 3 of 10
J_Dumont
Hi @jjstr8
Thanks for the reply. I will only need two separate families and just a few sizes of each, so I can use the row method. In this example, I determined which row I needed, and it failed. Any help would be greatly appreciated.
Here is updated code.
        oAsmDoc = g_inventorApplication.ActiveDocument
        oContentNode = oContentCenter.TreeViewTopNode.ChildNodes.Item("Sheet Metal").ChildNodes.Item("Nuts")
            If oFamily.DisplayName = "PEM Self-Clinching Nuts S,SS,CLS,CLSS - Inch" Then
                Exit For
            Else
                MsgBox("Family not found")
            End If
        Next
        If Not oFamily Is Nothing Then
            Dim memberFilename As String
            memberFilename = oFamily.CreateMember(14, failureReason, failureMessage, ContentMemberRefreshEnum.kDoNotRefreshOutOfDateParts)
            ' Place the part into the assembly.
            Dim transMatrix As Matrix
            transMatrix = g_inventorApplication.TransientGeometry.CreateMatrix
            'transMatrix.Cell(2, 4) = 0
            Dim Occ As ComponentOccurrence
            Occ = oAsmDoc.Occurrences.Add(memberFilename, transMatrix)
        End If
Here is the error
Message 4 of 10
JBerns
@J_Dumont,
I too wanted to learn how to insert Content Center parts using VB.NET.
Could you provide an example of the NND and NLG you want to place?
I found this source code, which originally inserted all the parts of a family.
Place Content Center Parts API Sample
I converted the code to a subroutine that receives arguments similar to the iLogic command. Currently, it supports a single column filter. In my case, I know StockNumber is unique.
Private Sub Main()
	Break
	Call PlaceFromContentCenter("Fasteners", "Washers", "Plain", "NMC Flat Washer - Inch", "Stock Number", "030-0254")
End Sub
''' <summary>
''' Place a component from Content Center using VB.NET
''' </summary>
''' <param name="oNode1">Category</param>
''' <param name="oNode2">Subcategory</param>
''' <param name="oNode3">SubSubCategory</param>
''' <param name="oFamilyName">Family name</param>
''' <param name="oColName">Column name</param>
''' <param name="oValue">Value to find</param>
Public Sub PlaceFromContentCenter(oNode1 As String, oNode2 As String, oNode3 As String, oFamilyName As String, oColName As String, oValue As String)
	Break
	logger.Trace("Entering PFCC")
    Dim asmDoc As AssemblyDocument = ThisApplication.Documents.Add(kAssemblyDocumentObject)
    Dim asmDef As AssemblyComponentDefinition = asmDoc.ComponentDefinition
    ' Get the node in the content browser based on the names of the nodes in the hierarchy.
'    Dim hexHeadNode As ContentTreeViewNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Fasteners").ChildNodes.Item("Washers").ChildNodes.Item("Plain")
    Dim hexHeadNode As ContentTreeViewNode = ThisApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item(oNode1).ChildNodes.Item(oNode2).ChildNodes.Item(oNode3)
    ' Find a specific family.  In this case it's using the display name, but any family
    ' characteristic could be searched for.
    Dim family As ContentFamily
    Dim checkFamily As ContentFamily
    For Each checkFamily In hexHeadNode.Families
'        If checkFamily.DisplayName = "NMC Flat Washer - Inch" Then
        If checkFamily.DisplayName = oFamilyName Then
            family = checkFamily
            Exit For
        End If
    Next
    Dim i As Integer = 0
    If Not family Is Nothing Then
        ' Place one instance of each member.
        Dim offset As Double
        offset = 0
        Dim row As ContentTableRow
		' Get column
		Dim oSNcol As Integer = 0
		For i = 1 To family.TableColumns.Count
'			If family.TableColumns.Item(i).DisplayHeading = "Stock Number" Then
			If family.TableColumns.Item(i).DisplayHeading = oColName Then
				oSNcol = i
				Exit For
			End If
		Next i
		' create member if value is found
        For Each row In family.TableRows
            ' Create the member (part file) from the table.
			If oSNcol <> 0 Then
'				If row.Item(oSNcol).Value = "030-0254" Then
				If row.Item(oSNcol).Value = oValue Then
					memberFilename = family.CreateMember(row, failureReason, failureMessage, kRefreshOutOfDateParts)
				Else
					memberFilename = Nothing
				End If
			End If
			Break
			If Not IsNothing(memberFilename) AndAlso memberFilename.Length <> 0 Then
				Dim transMatrix As Matrix = ThisApplication.TransientGeometry.CreateMatrix
				transMatrix.Cell(2, 4) = offset
				Dim Occ As ComponentOccurrence = asmDef.Occurrences.Add(memberFilename, transMatrix)
	            ' Compute the position for the next placement based on the size of the part just placed.
	            Dim minY As Double
	            Dim maxY As Double
	            minY = Occ.RangeBox.MinPoint.Y
	            maxY = Occ.RangeBox.MaxPoint.Y
	            offset = offset + ((maxY - minY) * 1.1)
			End If
        Next
    End If
End Sub
In the example above, I am searching for a plain flat washer having a specific stock number. Since the code originally placed multiple parts, you could remove a large portion of the code in lines 75-86 that increments the insertion point. For a single part, your would just need line 78.
I left commented lines in the code that represent the hard-coded search for that specific washer.
All that code above can make one appreciate how much work is going on inside the iLogic 'Components.AddContentCenterPart'
Dim Washer1 = Components.AddContentCenterPart(
   "Washer1",
   "Fasteners:Washers:Plain",
   { "StockNumber", "030-0254" },
   position := Nothing, grounded := False,
   visible := True, appearance := Nothing)
Let us know if this is helpful. Please mark as 'Accepted' if this answers your question.
Jerry
CAD Administrator
Using AutoCAD & Inventor 2025
Autodesk Certified Instructor
Autodesk Inventor 2020 Certified Professional
Autodesk AutoCAD 2017 Certified Professional
Message 5 of 10
jjstr8
Sorry, I should have specified that CreateMember is looking for a ContentIdentifier or the TableRow object, not just the index. Instead of 14, try oFamily.TableRows(14) or oFamily.TableRows(14).ContentIdentifier
Message 6 of 10
J_Dumont
Thanks for input.
This is what happens.
oFamily.TableRows(14) fails here.
oFamily.TableRows(14).ContentIdentifier fails here
Message 7 of 10
J_Dumont
Hi @JBerns
This looks great, thank you.
I'm working on getting the rows to work because I think that might be the simplest approach.
For PEM nuts, I would need to search for "Thread_Code" and "Shank_Code."
Message 8 of 10
jjstr8
Sorry, I was mistaken about using .ContentIdentifier and your earlier row number. It should take a TableRow(14), 14, or TableRow(14).InternalName. Regardless, where you add an occurrence, it needs to be to the ComponentDefinition, not the Document object.
Message 9 of 10
J_Dumont
It was an issue with the component definition.
Below is the code that is working.
Thank you both so much for replying and helping me with this issue.
        asmDef = oDoc.ComponentDefinition
        hexHeadNode = g_inventorApplication.ContentCenter.TreeViewTopNode.ChildNodes.Item("Sheet Metal").ChildNodes.Item("Nuts")
            If checkFamily.DisplayName = "PEM Self-Clinching Nuts S,SS,CLS,CLSS - Inch" Then
                Exit For
            End If
        Next
            offset = 0
            'Dim row As ContentTableRow
            memberFilename = family.CreateMember(14, failureReason, failureMessage, ContentMemberRefreshEnum.kDoNotRefreshOutOfDateParts)
            Occ = asmDef.Occurrences.Add(memberFilename, transMatrix)
        Else
            MsgBox("Content Center Family not Found for PEM Nuts.")
        End If
    End Sub
Message 10 of 10
JBerns
@J_Dumont,
You're welcome.
CAD Administrator
