Object for Vault Revision Table or Custom Revision Table
Bellmer-CAD-Admin
Bellmer-CAD-Admin
we use Vault and the Users should use only the "Vault Revision Table":
But for some reasons, sometimes (by mistake) User use the wrong one "Revision Table":
You can fix this by clicking "Populate with vault data". This will change the custom revision table to a vault revision table with data from vault.
Now we would like to check (via iLogic) the placed revision table if it's set to a "Vault Revision Table" but i cant find an object which differs from the Custom Revision Table:
Is there a way to find out if the placed Revision Table is a Vault Revision Table?
Thanks and BR
marcin_otręba
hi,
this is not possible to determine if revision table is vault because it is set up globally in project.
but maybe you can determine it trough something else like style name for example ?
if not then could you give us know what is your goal here ?
also if you set revision table as vault then it doesn't realy matters if you use vault revision or revision table button - it will place the same object. The difference is that vault revision will be filled with data and revision table not.
But for sure you could use UserInputEvents.OnTerminateCommand or ControlDefinitions here.
for example :
this will fill revision table with vault data
Dim rt As RevisionTable
Dim doc As DrawingDocument
doc = ThisApplication.ActiveDocument
rt = doc.ActiveSheet.RevisionTables(1)
doc.SelectSet.Select rt
ThisApplication.CommandManager.ControlDefinitions.Item("VaultRevisionBlockTableNode").Execute
or using UserInputEvents.OnTerminateCommand event you can use:
Private Sub Onterminate_Command(CommandName As String, Context As NameValueMap) Handles oUserInputEvents.OnTerminateCommand
            If CommandName = "VaultRevisionBlock" Then
            If CommandName = "DrawingRevisionTableCmd" Then
End Sub
hope this will help..
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
