insert ifeature with ilogic
Message 1 of 20
hi!
i want to insert a ifeatures with ilogic, my test code
' Get the part document and component definition of the active document.
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.ActiveDocument
Dim oPartDef As PartComponentDefinition
oPartDef = oPartDoc.ComponentDefinition
' Get the selected face to use as input for the iFeature.
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter,"SELECTIONNE Ta face" )
Dim oFeatures As PartFeatures
oFeatures = oPartDef.Features
' Create an iFeatureDefinition object.
Dim oiFeatureDef As iFeatureDefinition
oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition( _
"C:\IPSO2016\tab\PASSE_FILS.ide")
       ' Set the input.
    Dim oInput As iFeatureInput
    For Each oInput In oiFeatureDef.iFeatureInputs
        Dim oParamInput As iFeatureParameterInput
        Select Case oInput.Name
            Case "Sketch Position Plane1"
                Dim oPlaneInput As iFeatureSketchPlaneInput
                oPlaneInput = oInput
                oPlaneInput.PlaneInput = oFace
            Case "XA"
                oParamInput = oInput
                oParamInput.Expression = "1 in"
            Case "YA"
                oParamInput.Expression = "0.5 in"
        End Select
    Next
' Create the iFeature.
Dim oiFeature As iFeature
oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
but dont work, anybody can help me?
thanks for your help!
Replies (19)
Message 3 of 20
Thanks for your link Geork!
But her code dont work in ilogic.
Message 4 of 20
LishuangLu
Here's the sample code that can create iFeature based on a planar face, you may first open a part with a cube or create a new part, then run below iLogic Rule. Let me know whether it works for you.
Format:HTML Format Version:1.0 StartHTML: 165 EndHTML: 12804 StartFragment: 314 EndFragment: 12772 StartSelection: 314 EndSelection: 314SyntaxEditor Code Snippet
Public Sub Main()
    Dim oFace As Face
    oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a planar face")
"C:\Users\Public\Documents\Autodesk\Inventor 2018\Catalog\Slots\End_mill_curved.ide")
    ' Set the input.
            Case "Sketch Plane"
            Case "Diameter"
            Case "Depth"
        End Select
    Next
End Sub
-Lisa
Message 5 of 20
thanks for your reply
"C:\IPSO2016\PASSE_FILS.ide")
Message 6 of 20
LishuangLu
Does it work with Inventor's own iFeature file? If you are running with 2016, could you try with this iFeature "C:\Users\Public\Documents\Autodesk\Inventor 2016\Catalog\Slots\End_mill_curved.ide".
If above works, then it should be related with your iFeature, can you share the iFeature file with me for investigation?
-Lisa
Message 7 of 20
Yes work with that but i want to insert my custom ifeature in a specific place
Message 8 of 20
ok i find my problem 🙂
thansk again for your help 🙂
Message 9 of 20
anybody know if is possible to add a edge line selected axis direction in a code?
exemple:
Dim oFace As Face
oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "SELECTIONNE TON PART")
Dim oEdgeX As Edge
oEdgeX = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "SELECTIONNE TA DIRECTION EN X.")
Dim oEdgeY As Edge
oEdgeY = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartEdgeFilter, "SELECTIONNE TA DIRECTION EN Y.")
oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("I:\DOCUMENTS\ARTICLES\REFERENCE\IFEATURES\TROUS TAB.ide")
Case "FACE"
Case "DIRECTION X"
Dim oEdgeInput As iFeatureEdgeInput
oEdgeInput = oInput
oEdgeInput.EdgeInput = oEdgeX
Case "DIRECTION Y"
oEdgeInput = oInput
oEdgeInput.EdgeInput = oEdgeY
End Select
Next
thanks for your help 🙂
Message 10 of 20
LishuangLu
According to my investigation, there's no such iFeatureEdgeInput API object being exposed for doing this thing.
However, there's iFeatureEntityInput object that should take the edge object as entity, but when I tried declare iFeatureEntityInput and pass the edge object as Entity, I still get error when create the iFeature, looks there's something wrong in above logic. I guess this is a bug which hasn't been well implemented.
I'm going to track a bug into our internal bug system and ask our developer for investigation and fixing. So for now, we have no way to use a edge line as the  axis direction for iFeature creation. Sorry for the inconvenience.
-Lisa
Message 11 of 20
maybe it's possible with the part work axis x and y?
Message 12 of 20
ok i find my solution, i put the vertex axis in the part referenche sketch before i extract the ifeature and work great 🙂
thanks for all your help again!
Message 13 of 20
a ton of questions lol
I have another one, now i trying to change the position angle when i add my ifeature
my code work but with a differente angle?
Case "Sketch Plane1"
Dim oTG As TransientGeometry
oTG = ThisApplication.TransientGeometry
oPlaneInput.SetPosition(oTG.CreatePoint(0, 0, 0),oTG.CreateVector(1, 0, 0), 180)
End Select
 i want a position angle of 180 degre and my result is 53,24031 degre???
Message 14 of 20
martinhoos
Hi Lisa,
i am new with iFeature and iFeature place in.
I try to change your code that it works for me - without success! The iFeature i created is for the ends of Pipelines with the diameter 10, 12, 16 or 18mm. That means, i have pipelins with this diameters and i like to have the iFeature fixed to an end of this pipes regarding to the original diameter.
Please can you help me to get my Problem fixed?
Thank you very much....
Regards
Martin
Message 15 of 20
LishuangLu
@martinhoos, not sure whether I understand your requirement, so I tried to add the iFeature into the back face of your attached part with the position set to the center point of the back face with below VBA code. (Create a workpoint based on the back face first, then run the vba code and select the back face)
However, I got failure when run to the last code, and by confirming with our API team member, there seems to be a bug. Please let me know whether I understand your requirement.
Public Sub Main()
    Set oPartDoc = ThisApplication.ActiveDocument
    Set oPartDef = oPartDoc.ComponentDefinition
    Set oTG = ThisApplication.TransientGeometry
    Dim oVector As Vector
    Set oVector = oTG.CreateVector(0, 1, 0)
    Dim oPoint As Point
    Set oPoint = oPartDef.WorkPoints("Work Point1").Point
    Dim oFace As Face
    Set oFace = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kPartFaceFilter, "Select a planar face")
    Set oFeatures = oPartDef.Features
    Set oiFeatureDef = oFeatures.iFeatures.CreateiFeatureDefinition("C:\Users\Public\Documents\Autodesk\Inventor 2019\Catalog\Punches\curved slot.ide")
    ' Set the input.
            Case "Profile Plane1"
                Set oPlaneInput = oInput
                Call oPlaneInput.SetPosition(oPoint, oVector, 0)
            Case "Diameter"
                Set oParamInput = oInput
            Case "Depth"
        End Select
    Next
    Set oiFeature = oFeatures.iFeatures.Add(oiFeatureDef)
End Sub
Message 16 of 20
martinhoos
Hi Lisa,
thanks for your reply and for your help. I try to explain my Problem. I have a pipe
I like to insert the iFeature called "LongPilot_EXT.ide"  by selecting the pipe face and a point in the center of the pipe
The result Looks like
Enclose you will find the iFeature that i like to use.
Thanks again for your help.
Regards
Martin
Message 17 of 20
LishuangLu
Hi Martin,
Thanks for sharing more information! Based on my understanding, the VBA code provided by me can satisfy your requirement, but we have bug in creating such kind of iFeature through API right now. I will create a bug and ask our developer to do more investigation. Sorry for the inconvenience.
-Lisa
Message 18 of 20
martinhoos
Hi Lisa,
thanks for your reply. Bad news  - so we have to wait for the developer!
Regards from germany
Martin
PS: ... it is so close to Christmas - may be santa claus is bringing a solution . Wish you merry Christmas...
Message 19 of 20
LishuangLu
Thanks for your understanding, Martin!
Wish you merry Christmas! 🙂
-Lisa
Message 20 of 20
tech
Hi LishuangLu,
in your example you define one iFeatureSketchPlaneInput and two iFeatureParameterInput.
Is it possible define two iFeatureSketchPlaneInput, one for the Sketch and one for a work plane?
Many thanks!
Saulo
