Value Different From Answer Equation
Dear All,
I have a formula in the parameter list in a part. But the answer of the equation (is right) is different from the Value (Value is wrong). Why is this en how can i change this?
Kind Regards,
M. de Groot
Autodesk Inventor 2012
HermJan.Otterman
Can you share you (stripped) part? thanks
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
It seems that this problem only occurs when "d642" has a user parameter as equation. When I change this to, for example 500 or 250 . the formula changes directly and the answer is right
I don't think this is possible because of company related information
