I have created an iLogic to make a symbol legend on some of our drawings.
In doing so I have run into some issues:
1. Sometimes some of the symbols are placed in the bounds of a drawing view. If I move the drawing view, the symbols will move with the view, and the legend will be messed up. I can get around this by moving the drawing view, running the iLogic, and then moving the view back into place, but is there a way to place the symbol (with iLogic) directly on the sheet such that it won't move with a nearby drawing view?
2. Is there a way to determine the bounds of a sketched symbol so that the placement offsets can be dynamically calculated based on the size of the previous symbol placed? I know that this was not possible in 2013, but I wonder if that is still the case. Sometimes a symbol in the legend will be larger than others, and while I can make manual adjustments at the end, it would be nice if there was a way to determine the symbol bounds and place the following symbol accordingly.
