Sheet Metal Drawing automation
jaimin.ja.3
jaimin.ja.3
IS THERE ANY POSSIBITY TO AUTOMATE THIS PROCESS?
  • FROM ASSEMBLY OPEN SHEETMETAL COMPONENTS ONE BY ONE
  • OPEN DRAFTING FILE ANSI.idw (PATH - "C:\Users\Public\Documents\Autodesk\Inventor 2023\Templates\en-US\Metric\ANSI (mm).idw")
  • VIEW1 = PLACE BASE VIEW (Flat Pattern (Sheet Metal View))  (Style = Hidden Line Removed)
  • VIEW2 = PLACE ISOMATRIC VIEW (Style = Hidden Line Removed)
  • FOR THE SCALE AND POSITION OF THIS TWO VIEW CONSIDE FOLLOWING CODE
If ActiveSheet.View("VIEW1").Height < 250 Then
        ActiveSheet.View("VIEW1").Scale = 0.6
        ActiveSheet.View("VIEW1").SetCenter(175, 222)
        ActiveSheet.View("VIEW2").SetCenter(450,262.5)
ElseIf ActiveSheet.View("VIEW1").Height < 500 Then
        ActiveSheet.View("VIEW1").Scale = 0.4
ElseIf ActiveSheet.View("VIEW1").Height < 1000 Then
        ActiveSheet.View("VIEW1").Scale = 1/4.5
ActiveSheet.View("VIEW2").Scale = ActiveSheet.View("VIEW1").Scale
  • GIVE BEND ANNOTATION (FOR BEND ANNOTATION USE FOLLOWING CODE)
Dim oDoc As DrawingDocument
Dim oSheet As Sheet
Dim oView As DrawingView
Dim oCurve As DrawingCurve
Dim oBendNote As BendNote
Dim BendNoteCount As Integer
oDoc = ThisApplication.ActiveDocument
oSheet = oDoc.ActiveSheet
BendNoteCount = oSheet.DrawingNotes.BendNotes.Count
If BendNoteCount=0 Then
    '[add bend notes to views
	For Each oView In oSheet.DrawingViews
	 For Each oCurve In oView.DrawingCurves
	  If oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendDownEdge _
	  Or oCurve.EdgeType = Inventor.DrawingEdgeTypeEnum.kBendUpEdge Then
		' Create the bend note
		oBendNote = oSheet.DrawingNotes.BendNotes.Add(oCurve)
	 Next 'oCurve
	Next ']oView
	Else
	'do nothing
  • SAVE IDW FILE (IF POSSIBLE, FILE NAME SHOULD BE LIKE <PART NO> & <MATERIAL> & <THIKNESS>
  • EXPORT DWG FILE WITH SAME NAME
  • EXPORT PDF FILE WITH SAME NAME
SAVE THESE FILES IN TO SAME FOLDER
JelteDeJong
This rule is not finished (but I'm tired.) I guess that this does most of what you are looking for. Give it a try:
Sub Main()
    Dim doc As AssemblyDocument = ThisDoc.Document
    For Each refDoc As Document In doc.AllReferencedDocuments
        If (IsSheetmetal(refDoc) = False) Then Return
        Dim drawing = CreateNewDrawing()
        Dim flatView = CreateFlatpatternView(drawing.ActiveSheet, refDoc)
        Dim isoView = CreateIsoView(drawing.ActiveSheet, refDoc)
    Next
End Sub
Public Function IsSheetmetal(doc As Document) As Boolean
    Return doc.SubType = "{9C464203-9BAE-11D3-8BAD-0060B0CE6BB4}"
End Function
Public Function CreateNewDrawing() As DrawingDocument
    Dim templateFileName = "C:\Users\Public\Documents\Autodesk\Inventor 2023\Templates\en-US\Metric\ANSI (mm).idw"
    Return ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject, templateFileName)
End Function
Public Function CreateFlatpatternView(sheet As Sheet, doc As Document) As DrawingView
    Dim point = CreatePoint(17.5, 22.2)
    Dim nvm = ThisApplication.TransientObjects.CreateNameValueMap()
    nvm.Add("SheetMetalFoldedModel", False)
    Dim view = sheet.DrawingViews.AddBaseView(doc, point, 1, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle, "VIEW1",, nvm)
    SetScale(view)
    view.Center = point
    AddBendNotes(view)
    Return view
End Function
Public Function CreateIsoView(sheet As Sheet, doc As Document) As DrawingView
    Dim point = CreatePoint(45, 26.25)
    Dim view = sheet.DrawingViews.AddBaseView(doc, point, 1, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, "VIEW2")
    SetScale(view)
    view.Center = point
    Return view
End Function
Public Sub SetScale(view As DrawingView)
    view.Scale = 1
    If (view.Height < 25) Then
        view.Scale = 0.6
    ElseIf (view.Height < 500) Then
        view.Scale = 0.4
    ElseIf (view.Height < 1000) Then
        view.Scale = 1 / 4.5
End Sub
Public Function CreatePoint(x As Double, y As Double)
    Return ThisApplication.TransientGeometry.CreatePoint2d(x, y)
End Function
Public Sub AddBendNotes(view As DrawingView)
    Dim sheet = view.Parent
    For Each curve In view.DrawingCurves
        If (curve.EdgeType = DrawingEdgeTypeEnum.kBendDownEdge Or
                curve.EdgeType = DrawingEdgeTypeEnum.kBendUpEdge) Then
            sheet.DrawingNotes.BendNotes.Add(curve)
    Next
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
