Insert component at specific co-ordinates with iLogic
waynehelley
Message 1 of 9
waynehelley
Hi all,
I'm not sure if this has been asked before (I may have asked before!) but is it possible to use iLogic to insert a component at specific co-ordinates...
I have been using iLogic to insert using iMates but they can be very tedious to update if things need to change location.
Ideally I would just like to insert a component at specific co-ordinates and ground it.  Assume I have already orientated the component correctly.
Failing this...
I could create a bunch of 'Points' in the assembly environment, give them appropriate names, would it then be possible to constrain components to these points??
Please help!
Wayne Helley
Inventor 2013 Certified Professional
Autodesk Inventor Professional 2023
Visual Studio 2022
Windows 10 Pro, 64-bit
Replies (8)
Message 2 of 9
rossano_praderi
Hi Wayne,
I'm not sure of understanding your requirements but the code included in the attached file may help you with your final solution...
I also publish the code here:
Sub Main
	AddWP(100, 10, 20, "Test")
	AddComponent(100, 100, 0, ThisDoc.Path & "\Parte2.ipt") 'change the partname as you like
	MsgBox("Now I move the Component")
	MoveComponent(200, 300, 500, ComponentByName("Sfera"))
End Sub
Private Sub AddWP(x As Double, y As Double, z As Double, oName As String) ' this routine work on the activedocument
    ' Create a TransientGeometry
	oTG = ThisApplication.TransientGeometry
    ' Create 3 workpoints to define the origin, x-direction and y-direction points
    oWorkPoint = ThisApplication.ActiveDocument.ComponentDefinition.WorkPoints.AddFixed(oTG.CreatePoint(x,y,z))
	oWorkPoint.Name = oName
End Sub
Private Sub AddComponent(X As Double, Y As Double, Z As Double, oPath As String)
	If System.IO.File.Exists(oPath) Then
		oMatrix = oTG.CreateMatrix
		oMatrix.SetTranslation(oTG.CreateVector(X, Y, Z))
		' Add the occurrence
		oOccurrence = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.Add(oPath, oMatrix)
		oOccurrence.Grounded = False ' True to ground the component
		oOccurrence.Name = "Sfera" ' if you like to rename the occurence you can add the new name as parameter of this Sub
	End If
End Sub
Private Sub MoveComponent(X As Double, Y As Double, Z As Double, oOccurrence As ComponentOccurrence)
	If oOccurrence IsNot Nothing Then
		' Get the current transformation matrix from the occurrence.
		Dim oTransform As Matrix
		oTransform = oOccurrence.Transformation
		' Move the occurrence honoring any existing constraints.
		'oTransform.SetTranslation ThisApplication.TransientGeometry.CreateVector(oNOri.Point.X, oNOri.Point.Y, oNOri.Point.Z)
		'oOccurrence.Transformation = oTransform
		' Move the occurrence ignoring any constraints.
		' Anything that causes the assembly to recompute will cause the
		' occurrence to reposition itself to honor the constraints.
		oTransform.SetTranslation(ThisApplication.TransientGeometry.CreateVector(X, Y, Z))
		Call oOccurrence.SetTransformWithoutConstraints(oTransform)
	End If
End Sub
Private Function ComponentByName(oCname As String) As ComponentOccurrence
	ComponentByName = Nothing
	For Each oOcc In ThisApplication.ActiveDocument.ComponentDefinition.Occurrences
		If oOcc.Name = oCname Then
			ComponentByName = oOcc
			Exit Function
		End If
	Next
End Function
 Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
Message 3 of 9
waynehelley
Thanks very much... that is exactly what I needed!
My only issue now is that i have a few components that were modelled backwards so it would be great to be able to rotate when using the 'AddComponent' sub
'Insert code here which would rotate the component by 180 degrees around its own Y-axis
oOccurrence.Grounded = True ' oOccurrence.Name = "Sfera" ' if you like to rename the occurence you can add the new name as parameter of this Sub End If End Sub
Wayne Helley
Visual Studio 2022
Message 4 of 9
rossano_praderi
Hi Wayne,
I've made few modifications on my posted example, if want to rotate the component of 180° on insertion, this can be a solution.
Public Sub AddComponent(X As Double, Y As Double, Z As Double, oPath As String)
		Dim oAsmCompDef As AssemblyComponentDefinition = ThisApplication.ActiveDocument.ComponentDefinition
		Dim oTG As TransientGeometry = ThisApplication.TransientGeometry
		Dim oMatrix As Matrix = oTG.CreateMatrix
		Call oMatrix.SetToRotation(3.14159265358979, oTG.CreateVector(0, 1, 0), oTG.CreatePoint(X / 10, Y / 10, Z / 10)) ' Rotate of 180° on axis Y
		Call oMatrix.SetTranslation(oTG.CreateVector(X / 10, Y / 10, Z / 10))
		Dim oOcc As ComponentOccurrence = oAsmCompDef.Occurrences.Add(oPath, oMatrix)
	End If
End Sub
For your information, you will find more details about occurrences positioning.
http://forums.autodesk.com/t5/inventor-customization/settorotation-question/td-p/2488976
http://forums.autodesk.com/t5/inventor-general-discussion/place-component-automatically-to-the-xz-pl...
This is a link to a very useful guide
http://modthemachine.typepad.com/files/mathgeometry.pdf
Bregs
Rossano Praderi
Message 5 of 9
Frodl
this is a great code.
Is it also possible to rotate one and the same component first around the y-axis (as in your code), second around the x-axis and last around the z-axis?
I tried but did not get it.
Is it possible do rotate around all the axis at once or must this happend step by step?
Thank you for your help.
Message 6 of 9
rossano_praderi
yes you can do many changes at once by changing the matrix object, as explained in the follow link (already shared in my last post).
Bregs
Rossano Praderi
Message 7 of 9
Frodl
thank you for the answer. The document in the link I've read before. But I've some problems to get the necessary code.
Meanwhile I've found the solution:
		' Erzeugen einer Matrix zur Rotation der Tübbingringe - Drehung um die z-Achse um den 180° wegen umgekehrter Orientierung Tübbingmodell
		Dim oTrans_Matrix As Matrix = oTG.CreateMatrix
		Call oTrans_Matrix.SetToRotation(PI, oTG.CreateVector(0, 0, 1), oTG.CreatePoint(X, Y, Z)) ' Rotation um Y-Achse
		' Erzeugen einer Matrix zur Rotation um die y-Achse um den Winkel roty
		Dim oMatrix_y As Matrix = oTG.CreateMatrix
		Call oMatrix_y.SetToRotation(PI/180*roty, oTG.CreateVector(0, 1, 0), oTG.CreatePoint(X, Y, Z)) ' Rotation um Y-Achse
		Call oTrans_Matrix.TransformBy(oMatrix_y)
		' Erzeugen einer Matrix zur Rotation um die z-Achse um den Winkel rotz und hinzufügen zur vorherigen Matrix
		Dim oMatrix_z As Matrix = oTG.CreateMatrix
		Call oMatrix_z.SetToRotation(PI/180*rotz, oTG.CreateVector(0 , 0 , 1), oTG.CreatePoint(X , Y , Z )) ' Rotation um Z-Achse
		Call oTrans_Matrix.TransformBy(oMatrix_z)
		' Erzeugen einer Matrix zur Rotation um die x-Achse um den Winkel rotz und hinzufügen zur vorherigen Matrix
		Dim oMatrix_x As Matrix = oTG.CreateMatrix
		Call oMatrix_x.SetToRotation(PI/180*rotx, oTG.CreateVector(1 , 0 , 0), oTG.CreatePoint(X , Y , Z )) ' Rotation um X-Achse
		Call oTrans_Matrix.TransformBy(oMatrix_x)
		Call oTrans_Matrix.SetTranslation(oTG.CreateVector(X, Y, Z))
		Dim oOcc As ComponentOccurrence = oAsmCompDef.Occurrences.Add(oPath, oTrans_Matrix)
		oOcc.Grounded = True ' "True" zum Fixieren des Bautels, "False" für keine Fixierung
		oOcc.Name = "Ring_"&Ringnr ' if you like to rename the occurence you can add the new name as parameter of this Sub
Message 8 of 9
SharkDesign
I used the code from https://modthemachine.typepad.com/files/mathgeometry.pdf but I get the error
'Error on Line 18 : 'Let' and 'Set' assignment statements are no longer supported.'
  Inventor Certified Professional
Message 9 of 9
rossano_praderi
Hi James,
the referenced document (https://modthemachine.typepad.com/files/mathgeometry.pdf) contain samples macros written in VBA wich use the "Set" statement (for reference https://docs.microsoft.com/en-us/office/vba/language/reference/user-interface-help/set-statement) , this statement is not used in the Ilogic code ti assign object variables/properties.
Then if this is the case, remove the "Set" statement from your code.
Otherwise give us more details about your code.
Bregs
Rossano Praderi
