Hi Wayne,
I'm not sure of understanding your requirements but the code included in the attached file may help you with your final solution...
I also publish the code here:
Sub Main
AddWP(100, 10, 20, "Test")
AddComponent(100, 100, 0, ThisDoc.Path & "\Parte2.ipt") 'change the partname as you like
MsgBox("Now I move the Component")
MoveComponent(200, 300, 500, ComponentByName("Sfera"))
End Sub
Private Sub AddWP(x As Double, y As Double, z As Double, oName As String) ' this routine work on the activedocument
' Create a TransientGeometry
oTG = ThisApplication.TransientGeometry
' Create 3 workpoints to define the origin, x-direction and y-direction points
oWorkPoint = ThisApplication.ActiveDocument.ComponentDefinition.WorkPoints.AddFixed(oTG.CreatePoint(x,y,z))
oWorkPoint.Name = oName
End Sub
Private Sub AddComponent(X As Double, Y As Double, Z As Double, oPath As String)
If System.IO.File.Exists(oPath) Then
oMatrix = oTG.CreateMatrix
oMatrix.SetTranslation(oTG.CreateVector(X, Y, Z))
' Add the occurrence
oOccurrence = ThisApplication.ActiveDocument.ComponentDefinition.Occurrences.Add(oPath, oMatrix)
oOccurrence.Grounded = False ' True to ground the component
oOccurrence.Name = "Sfera" ' if you like to rename the occurence you can add the new name as parameter of this Sub
End If
End Sub
Private Sub MoveComponent(X As Double, Y As Double, Z As Double, oOccurrence As ComponentOccurrence)
If oOccurrence IsNot Nothing Then
' Get the current transformation matrix from the occurrence.
Dim oTransform As Matrix
oTransform = oOccurrence.Transformation
' Move the occurrence honoring any existing constraints.
'oTransform.SetTranslation ThisApplication.TransientGeometry.CreateVector(oNOri.Point.X, oNOri.Point.Y, oNOri.Point.Z)
'oOccurrence.Transformation = oTransform
' Move the occurrence ignoring any constraints.
' Anything that causes the assembly to recompute will cause the
' occurrence to reposition itself to honor the constraints.
oTransform.SetTranslation(ThisApplication.TransientGeometry.CreateVector(X, Y, Z))
Call oOccurrence.SetTransformWithoutConstraints(oTransform)
End If
End Sub
Private Function ComponentByName(oCname As String) As ComponentOccurrence
ComponentByName = Nothing
For Each oOcc In ThisApplication.ActiveDocument.ComponentDefinition.Occurrences
If oOcc.Name = oCname Then
ComponentByName = oOcc
Exit Function
End If
Next
End Function Bregs
Rossano Praderi
If my post answers your question, please click the "Accept as Solution"
button. This helps everyone find answers more quickly!
