Initialize values on an ilogic form
akaluri
akaluri
Hello Guys,
I have an ilogic form and when I open it, currently it contains the values I previously set. Is there any way I can make the fields blank while opening?
Sergio.D.Suárez
Hello, Usually when you create a form, those values that you enter come from the parameters of the document, and then based on these parameters you will perform an action. You could define the value in zero of each parameter at the end of the action, as long as the zero value does not continue modifying the actions that I previously performed. Could you attach your file here to study it? regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
