Editing a hatch pattern in Title Blocks
llorden4
llorden4
Hatch pattern editors seem to be non-existent in a Title Block editor.  I can create a hatch/fill pattern without any issues but deleting or editing is not an option and once made I appear to be forever stuck with the pattern and the only option appears to delete the objects that defined the boundaries for the fill.
Are there other options other than a complete do-over?
Running 2018 Pro
Autodesk Inventor Certified Professional
chandra.shekar.g
Autodesk Support
Autodesk Support
@llorden4,
Hatch pattern can be edited through Hatch style that is used to fill boundary.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
llorden4
It took a bit of figuring out, but I did find the method to go along with the "yes it can" response.  It's not very intuitive, but to edit a hatch in the title block editor, you have to actually activate the Fill/Hatch command first and not just double left click on the hatch or right click to call up the hatch editor.  The Fill command then becomes your selector and if you select the same area a hatch is already in, then it becomes an editor.
Toggling the tiny hatch box in the top left corner of this dialog box will delete or activate the hatch.
