Import list of ipt in text file into iam?
G60Dubs
G60Dubs
Hi
In the process of trying to correct file errors in order to check files into Vault (via Task Scheduler)
I have a list of files in a spreadhseet and at present I am opening one at a time, correcting the error and then checking in.    Is there a way to bulk import a list of ipt in say a text file, into an iam or another method of opening a txt list of files in Inventor?  This would save me hours of time having to CTRL c, CTRL v the file path into explorer for opening.
bradeneuropeArthur
With this yes:
Dim a As AssemblyDocument = ThisAssembly.Document
Dim ac As AssemblyComponentDefinition = a.ComponentDefinition
For Each Line In System.IO.File.ReadLines("D:\_Tests\Load.txt")
MsgBox(Line)
Dim identity As Matrix
identity = ThisApplication.TransientGeometry.CreateMatrix
Dim aoc As ComponentOccurrence =  ac.Occurrences.Add(Line,identity)
Next
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
G60Dubs
Nice.   Is there any way to supress and skip unresolved files as these will error the code?
G60Dubs
Not solved.   The proposed solution provides no benefit as any error in file resolution on file open or similar kicks the program out.    How would one suppress any and all errors during on each subsequent file open?
bradeneuropeArthur
Try this:
Dim inv As Inventor.Application= ThisApplication
inv.FileOptions.FileOpenOptions.SkipAllUnresolvedFilesInAssembly = True
inv.FileOptions.FileOpenOptions.SkipAllUnresolvedFilesInDrawing = True
inv.FileOptions.FileOpenOptions.SkipAllUnresolvedFilesInPart = True
MsgBox(Line)
Next
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
G60Dubs
Yeah that's definetely heading the right way.
Sorry for the delay in reply - Discovered my email was junkng everything from the autodesk domain.
I do notice an issue where the 'FileOpenOptions.SkipAllUnresolvedFilesInPart' fails - Suppressed links with base components where the base component is unresolved.
Maybe one for a Dev to investigate?
