Import Excel Table into Drawing using ilogic
I have been trying to import my excel table in the directory;
C:\Users\tm04.smeric\Desktop\Meric\EXCEL NOZZLE LIST.xlsm
into my drawing, the excel table constantly changes since I have another rule that updates it with the iProperties of the current drawing/project.
If anyone knows how I can implement a rule to import the table that is created on "Sheet1" I'd greatly appreciate it.
Thanks in advance
bradeneuropeArthur
Take a look at this:
AddExcelTable(ExcelFileName As String, PlacementPoint As Point2d, [Title As String], [StartCell As String = "A2"], [ColumnHeaderRow As Long = 1]) As CustomTable
lLike this:
Public Sub CreateDrawingExcelTable()
    ' Set a reference to the active drawing document
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    ' Set a reference to the active sheet
    Dim oActiveSheet As Sheet
    Set oActiveSheet = oDrawDoc.ActiveSheet
    ' Create the placement point for the table
    Dim oPoint As Point2d
    Set oPoint = ThisApplication.TransientGeometry.CreatePoint2d(25, 25)
    ' Create the table by specifying the source Excel file
    ' This assumes that the first row in the Excel sheet specifies the column headers
    ' You can specify a different row using the last argument of the AddExcelTable method
    Dim oExcelTable As CustomTable
    Set oExcelTable = oActiveSheet.CustomTables.AddExcelTable("C:\Temp\test.xls", oPoint, "Excel Table")
End Sub
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
