Hi @Lewis.Young,
This rule of mine:
Sub Main()
If TypeOf ThisApplication.activeDocument Is AssemblyDocument Or TypeOf ThisApplication.activeDocument Is PartDocument Then
Call OpenExcel("\\PEBBLES\Drawings\Component Drawings\Post NAV Drawings\Drawing List.xlsx")
End If
If TypeOf ThisApplication.activeDocument Is AssemblyDocument Then
If disableBOMRowMerge Then
Dim ThisBOM As BOM = ThisApplication.activeDocument.componentdefinition.BOM
ThisBOM.SetPartNumberMergeSettings(False)
End If
Dim thisAssy As assemblydocument = ThisApplication.activeDocument
For Each subdoc as Inventor.Document In thisAssy.ReferencedDocuments
If TypeOf subdoc Is PartDocument Then
updatestatusbar(subdoc.FullFileName)
For Each product As CSProduct In CSProductList
Dim docname As String = System.io.Path.getfilenamewithoutextension(subdoc.Displayname) & ":1"
Dim partno As String = iProperties.Value(docname, "Project", "Part Number")
If partno.contains(product.DrawingNumber) Then
AssigniProperties(subdoc,product)
Exit For
End If
Next
End If
Next
ElseIf TypeOf ThisApplication.activeDocument Is PartDocument Then
Dim ThisPart As partdocument = ThisApplication.activeDocument
Dim partno As String = iProperties.Value("Project", "Part Number")
AssigniProperties(product)
Exit For
End If
Next
End If
'___Use windows voice command____________
Dim objSPVoice,colVoices
objSPVoice = CreateObject("SAPI.SpVoice")
objSPVoice.Speak ("i Logic Rules complete")
End Sub
Public CSProductList As list(Of CSProduct)
Public MaxExcelRow As Integer = 800
Public disableBOMRowMerge As Boolean = True
Sub OpenExcel(ByVal Filename As String)
'MessageBox.Show(Filename, "Title")
updatestatusbar("Working with Excel, hold tight!")
GoExcel.Open(Filename, "Components")
CSProductList = New list(Of CSProduct)
Dim percent As Double = Nothing
For cellrow As Integer=4 To MaxExcelRow
Dim columnLetter As String = "A"
percent = (CDbl(cellrow) / MaxExcelRow)
updatestatusbar(percent, "Percentage complete during get of Excel Data is:")
If GoExcel.CellValue(columnLetter & CStr(cellrow)) = "" Then
Continue For
End If
Dim product As CSProduct
product = New CSProduct
product.drawingnumber = GoExcel.CellValue(columnLetter & CStr(cellrow))
columnLetter="C"
product.description = GoExcel.CellValue(columnLetter & CStr(cellrow))
columnLetter="E"
product.itemcode = GoExcel.CellValue(columnLetter & CStr(cellrow))
CSProductList.add(product)
Next
GoExcel.Close()
updatestatusbar("list count= "& csproductlist.count)
'MessageBox.Show("list count= "& csproductlist.count, "Title")
End Sub
Sub AssigniProperties (ByVal ThisDoc as document, ByVal product As CSProduct)
'MsgBox(ThisDoc.FullFileName)
updatestatusbar(ThisDoc.FullFileName)
Dim docname As String = System.io.Path.getfilenamewithoutextension(ThisDoc.Displayname) & ":1"
iProperties.Value(docname, "Project", "Part Number") = product.itemCode & "-" & product.DrawingNumber
iProperties.Value(docname, "Project", "Description") = product.Description
End Sub
Sub AssigniProperties (ByVal product As CSProduct)
updatestatusbar(ThisApplication.activeDocument.FullFileName)
iProperties.Value("Project", "Part Number") = product.itemCode & "-" & product.DrawingNumber
iProperties.Value("Project", "Description") = product.Description
End Sub
Sub updatestatusbar(ByVal message As String)
ThisApplication.statusbartext = message
End Sub
Sub updatestatusbar(ByVal percent As Double, ByVal message As String)
ThisApplication.statusbartext = message + " (" & percent.tostring("P1") + ")"
End Sub
'This is our Product Class
Class CSProduct
Public DrawingNumber As String
Public Description As String
Public ItemCode As String
Public Sub init (m_DrawingNumber As String ,
m_description As String,
m_itemcode As String)
DrawingNumber = m_DrawingNumber
Description = m_description
ItemCode = m_itemCode
End Sub
End Class
from my iLogic library here:
https://github.com/AlexFielder/iLogic
will do what you want with a bit of a tweak.
Basically, in its current form, when you run it in a part or Assembly, the rule will open an Excel spreadsheet, capture the data from it and then compare the a part number from the current part or occurrence with the list of information and populate the iProperties accordingly.
The tweak for your needs would be to prompt the user for input instead of (blindly) searching the list.
If there is no match then MessageBox.show("No match") would suffice.
