iLogicVB problem
iLogicVB problem
DWhiteley
Advisor Advisor
iLogicVB problem
DWhiteley
I'm using VB.NET
I am referencing AUTODESK.ILOGIC.INTERFACES.DLL
I have added this code:
Imports Autodesk.iLogic.Interfaces
Public iLogicVb As ILowLevelSupport
And getting this error:
Type 'ILowLevelSupport' is not defined.
What am I doing wrong?
Dave
MechMachineMan
If you are already using VB.net, why are you trying to get back into the iLogic Addin which accesses the API indirectly, instead of calling the function you want directly from Inventor/Excel API?
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
DWhiteley
Because I'm trying to run this:
iLogicVb.Automation.RulesOnEventsEnabled = false
MechMachineMan
I think maybe using iLowLevelSupport is the wrong means to access it.
Property:Autodesk.iLogic.Interfaces.IiLogicAutomation.RulesEnabled
Description: Set this to False to disable rules running in response to parameter changes or other events. Set this to True to re-enable rule running.  This will also clear any rule errors that may have disabled rules from running.
See this thread and the attached file there for a breakdown of more of the accessible API features.
https://forums.autodesk.com/t5/inventor-customization/ilogic-api-documentation/td-p/6785772
Justin K
DWhiteley
I'm nearly there!
Public Class Form1
Public oiLogic As IiLogicAutomation
oiLogic.RulesOnEventsEnabled = True
Get error - Type 'IiLogicAutomation' is not defined. As soon as I do a build.
I cannot use autodesk.ilogic.interfaces.LilogicAutomation.RulesEnabled=false (same sort of problem)
Dave
chandra.shekar.g
Autodesk Support
Autodesk Support
Hi Dave,
Please find the following sample code to set RulesOnEventsEnabled to false
Dim addinGUID As String = "{3BDD8D79-2179-4B11-8A5A-257B1C0263AC}"
Dim addin As Inventor.ApplicationAddIn
addin = m_inventorApplication.ApplicationAddIns.ItemById(addinGUID) If addin IsNot Nothing Then
addin.Activate() Dim oilogic As Autodesk.iLogic.Automation.iLogicAutomation oilogic = addin.Automation oilogic.RulesOnEventsEnabled = False
Please feel free to contact if there is any doubt.
If solves your problem, click on "Accept as solution" / give a "Kudo"
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
