AddByPlaneAndOffset used in an assembly
oransen
oransen
The Inventor 15 API says that AddByPlaneAndOffset is not supported in assemblies. Will that change/has that changed in later releases. It would be very useful, and can be done "manually" so why not programatically...?
TIA!
oransen
I'm replying because I've found an alternative which might help others. I needed a function which, in an assembly, created a sketch offset from one of the standard planes. Here's the full C++ function:
bool CreateSketchOffsetFromXYPlaneInAsm (CComPtr<AssemblyComponentDefinition>& pAsmCompDef,  // where the sketch will be added
                                         CComPtr<PlanarSketch>& pNewSketch,     // The sketch created, an output
                                         const double kOffsetMm,
                                         const wchar_t* const pszSketchName)    // Name of the newly created sketch
    // Get PlanarSketches, the list of sketches
    CComPtr<PlanarSketches> pSketches = nullptr ;
    HRESULT hRes = pAsmCompDef->get_Sketches(&pSketches);
    if (FAILED(hRes) || (pSketches == nullptr)) {
        ShowCOMError (hRes,L"CXYPOSIA, get_Sketches failed") ;
        return false ;
    // Get standard default WorkPlanes, probably 3 only initially in the list
    CComPtr<WorkPlanes> pWorkPlanes = nullptr ;
    hRes = pAsmCompDef->get_WorkPlanes(&pWorkPlanes);
    if (FAILED(hRes) || (pWorkPlanes == nullptr)) {
        ShowCOMError (hRes,L"CXYPOSIA, get_WorkPlanes failed") ;
        return false ;
    // Get hold of one of the WorkPlanes. Valid indices are 1L 2L 3L for standard workplanes
    CComPtr<WorkPlane> pXYWorkPlane = nullptr ;
    hRes = pWorkPlanes->get_Item(_variant_t(3L, VT_I4),&pXYWorkPlane);
    if (FAILED(hRes) || (pXYWorkPlane == nullptr)) {
        ShowCOMError (hRes,L"CXYPOSIA, get_Item (workplane) failed") ;
        return false ;
    CComPtr<TransientGeometry> pTransGeom = theApp.GetTransGeomPtr () ;
    CComPtr<Point> pOrigin = nullptr ;
    hRes = pTransGeom->CreatePoint (0,0,0,&pOrigin);
    CComPtr<UnitVector> UnitXVector ;
    pTransGeom->CreateUnitVector (1.0,0,0,&UnitXVector) ;
    CComPtr<UnitVector> UnitYVector ;
    pTransGeom->CreateUnitVector (0.0,1.0,0,&UnitYVector) ;
    // Internally Inventor always uses cm, so convert...
    const double kOffsetInCm = kOffsetMm/10.0 ;
    pOrigin->PutZ (kOffsetInCm) ;
    CComPtr<WorkPlane> pOffsetWorkPlane ;
    hRes = pWorkPlanes->AddFixed(pOrigin,UnitXVector,UnitYVector,VARIANT_FALSE,&pOffsetWorkPlane) ;
    if (pOffsetWorkPlane == nullptr) {
        gLogger.Printf (ekErrMsg,L"CXYPOSIA, Could not AddFixed") ;
        return false ;
    // Now actually create a sketch and get a pointer to it in one go...
    hRes = pSketches->Add (_variant_t((IDispatch *)pOffsetWorkPlane),
                           VARIANT_FALSE,
                           &pNewSketch);
    if (FAILED(hRes)) {
        ShowCOMError (hRes,L"CXYPOSIA, AddSketch failed") ;
        return false ;
    pNewSketch->put_Name (BSTR(pszSketchName)) ;
    return true ;
