iLogic
iLogic
Sam.Abdallah
iLogic
Sam.Abdallah
Hi
I'm trying to suppress/activate features in a part
If condition A is true
 Set_features (hole1, hole2...)
 if ofeature = Set_features then
 Feature.IsActive ( ofeature) = True
Else
 Feature.IsActive ( ofeature) = False
My question is how to define a set of features?
Sam.Abdallah
This is what I got for parts in assembly, but doesn't work. Any suggestions?
SyntaxEditor Code Snippet
' GROUP MEMBERS TO ACTIVATE/SUPPRESS
MEMBER1GROUP = New String(){"MEMBER1"}
'SELECT MEMBERS THAT ARE REQUIRED
If MEMBER_1 = 1 Then
        For Each Value As String In MEMBER1GROUP
            Try
                If Value = MEMBER1GROUP Then
                Component.IsActive(Value) = True
                Else
                Component.IsActive(Value) = False
            Catch
            End Try
        Next
MechMachineMan
A similar solution was made in the proposed in the past:
https://forums.autodesk.com/t5/inventor-forum/additional-parameters-in-ilogic-string/m-p/6810149/hig...
Sub Main()
    'Take your old iLogic and put it in a Sub Main/End Sub Wrap.
     If Band_Lengte = 900 Then
              Poot_Afstand_1 = 80
              Poot_Afstand_2 = 600
              Aandrijf_Afstand = 145
            'Swap your old call with the new one
              'Feature.IsActive("Poot Pattern2","Poot Pattern3","Gaten_Span")=False
              FeaturesActive(False, "Poot Pattern2", "Poot Pattern3", "Gaten_Span")
    End if
End Sub
'Copy/paste this sub into the same rule and don't touch anything in it.
Sub FeaturesActive(boolActive As Boolean, ByVal ParamArray features As String())
 For Each i As String In features
    Feature.IsActive(i) = boolActive
  Next
End Sub
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Sam.Abdallah
Thanks Justin
Thanks for your reply.
I did see that thread. As you said, it will solve the 'suppress/activate' action. But I intend to use the group execute other actions, may be, change material, change supplier, etc.
Essentially, I'm after
1. creating a group for parts, for example:
MEMBER1GROUP = New String(){"MEMBER1", "MEMBR2", ....}
2. Loop to action for each member of that group, for example:
            Try
                Else
            Catch
            End Try
        Next
This approach will allow me to add members to a group at later stage and add/change actions to be executed to members in selected groups
Sam.Abdallah
I guess I figured it out. Just had to simplify the statements
'Create member group
MEMBER1GROUP = New String(){"MEMBER1", "MEMBER2", "MEMBER3"}'Create action: suppres / activate condition
For Each VALUE In MEMBER1GROUP
    If MEMBER_1 = 0 Then
    Component.IsActive(VALUE)=False
    ElseIf MEMBER_1 = 1 Then
    Component.IsActive(VALUE)=True
Next
