Message 1 of 10
iLogic V2021 problem
this iLogic worked perfectly for me until the V2021. Can anyone help? When I run it, Inventor crashes
'check for custom iProperty and add it if not found
Dim prefix As String = "Prefix"
customPropertySet = ThisDoc.Document.PropertySets.Item _
("Inventor User Defined Properties")
Try
prop= customPropertySet.Item(prefix)
Catch
' Assume error means not found
customPropertySet.Add("", prefix)
End Try
'write the part number to the Prefix iProperty if it is empty
If iProperties.Value("Custom", "Prefix") = "" Then
iProperties.Value("Custom", "Prefix") = iProperties.Value("Project", "Part Number") & "_"
Else
'check that this active document is a part file
Dim partDoc As PartDocument
If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
MessageBox.Show ("Please open a part document", "iLogic")
'define the active document
partDoc = ThisApplication.ActiveDocument
Dim solid As SurfaceBody
Dim i As Integer
'get input from user
prefix = InputBox("Enter a prefix for the solid body names", "iLogic", iProperties.Value("Custom", "Prefix"))
'write input back to custom iProperty
iProperties.Value("Custom", "Prefix") = prefix
i = 1
'rename all solid bodies incrementing suffix
For Each solid In partDoc.ComponentDefinition.SurfaceBodies
solid.Name = prefix + Iif(i < 10, "0" + CStr(i), CStr(i))
i = i + 1
Next
