iLogic V2021 problem
kresh.bell
Message 1 of 10
kresh.bell
this iLogic worked perfectly for me until the V2021. Can anyone help? When I run it, Inventor crashes
'check for custom iProperty and add it if not found
Dim prefix As String = "Prefix"
customPropertySet = ThisDoc.Document.PropertySets.Item _
("Inventor User Defined Properties")
Try
         prop= customPropertySet.Item(prefix)
Catch
      ' Assume error means not found
            customPropertySet.Add("", prefix)
End Try
'write the part number to the Prefix iProperty if it is empty
If iProperties.Value("Custom", "Prefix") = "" Then
iProperties.Value("Custom", "Prefix") = iProperties.Value("Project", "Part Number") & "_"
Else
End If
'check that this active document is a part file
Dim partDoc As PartDocument
If ThisApplication.ActiveDocument.DocumentType <> kPartDocumentObject Then
MessageBox.Show ("Please open a part document", "iLogic")
End If
'define the active document
partDoc = ThisApplication.ActiveDocument
Dim solid As SurfaceBody
Dim i As Integer
'get input from user
prefix = InputBox("Enter a prefix for the solid body names", "iLogic", iProperties.Value("Custom", "Prefix"))
'write input back to custom iProperty
iProperties.Value("Custom", "Prefix") = prefix
i = 1
'rename all solid bodies incrementing suffix
For Each solid In partDoc.ComponentDefinition.SurfaceBodies
solid.Name = prefix + Iif(i < 10, "0" + CStr(i), CStr(i))
i = i + 1
Next
Replies (9)
Message 2 of 10
kresh.bell
... same problem with this iLogic
Public Sub Main()
Dim a As Application
 a = ThisApplication
Dim b As PartDocument
 b = a.ActiveDocument
 Try
 Dim p As Inventor.Property = b.PropertySets.Item(4).Add("", "Prefix")
 Catch
 End Try
Dim c As SurfaceBody
Dim d As SurfaceBodies
Dim E As SelectSet
E = b.SelectSet
If E.Count = 0 Then
MsgBox ("select something")
Else
Dim i As Integer
prefix = InputBox("Enter a prefix for the solid body names", "iLogic", iProperties.Value("Project", "Part Number") & "_")
'iProperties.Value("Custom", "Prefix") = prefix
i = 1
For Each c In E
c.Name = prefix + IIf(i < 10, "0" + CStr(i), CStr(i))
i = i + 1
Next
'e.Name = ""
End If
End Sub
Message 3 of 10
Michael.Navara
I test your code snippets and both woks fine as local rule. Without crash.
(WIN 10 + Inventor 2021 (x64, Build 183)
Message 4 of 10
kresh.bell
I don't understand, what could be the problem? I run this iLogic as an external rules
Message 5 of 10
marcin_otręba
I tried and both work fine. Could you provide your sample files to test it ?
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
Message 6 of 10
Sergio.D.Suárez
A tip, when you find bugs in ilogic that work in other inventor versions and don't throw bugs, try to fully define the variables. It has happened to me that by not defining all the variables some codes threw errors.
Dim customPropertySet As Inventor.PropertySet = ThisDoc.Document.PropertySets.Item _
Try
Catch
End Try
Else
End If
End If
Dim i As Integer
i = 1
solid.Name = prefix + IIf(i < 10, "0" + CStr(i), CStr(i))
i = i + 1
Next
 I hope you can solve the problem soon. Cheers
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
Message 7 of 10
kresh.bell
I still have a problem. Can you try on this file?
Message 8 of 10
marcin_otręba
it is not ilogic fault. Try to change any first body name manually, and inventor will crush as well.
Message 9 of 10
marcin_otręba
i tried on my file with multiple bodies and it works.
Message 10 of 10
kresh.bell
yes, the problem seems to be something else, thanks guys
