iLOGIC user parameters from Ipt to Ipt
SpokenEarth
Message 1 of 18
SpokenEarth
Hi forum, i need a code for export or import user parameters from one part to another.
Can anyone give me a solution
Replies (17)
Message 2 of 18
bradeneuropeArthur
do you mean export .xml and import .xml?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
Message 3 of 18
SpokenEarth
Not in xml
Message 4 of 18
bradeneuropeArthur
What do you mean than with Export and Import?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 5 of 18
SpokenEarth
Import or export user parameters so can be used as a reference
Message 6 of 18
bradeneuropeArthur
Can you use "Derive Parameters" than, because you need it as a reference?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 7 of 18
SpokenEarth
Yes. If you can open my attached file you can se i have a view parameters, i would like to export them to another part so can be used as reference, without first derived my part.
Message 8 of 18
bradeneuropeArthur
So this means No reference!
There will be only a one-go and not a link between those?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 9 of 18
SpokenEarth
Exactly
Message 10 of 18
bradeneuropeArthur
With:
Ilogic
Vba
Vb.net
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 11 of 18
SpokenEarth
Rather with Ilogic, please
Message 12 of 18
bradeneuropeArthur
Only the user defined parameters?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 13 of 18
bradeneuropeArthur
Dim d As Inventor.FileDialog
Dim td As Inventor.PartDocument = ThisDoc.Document
Call ThisApplication.CreateFileDialog(d)
d.ShowOpen
Dim pd As Inventor.PartDocument = ThisApplication.Documents.OpenWithOptions(d.FileName,"" , False)
For Each p As Inventor.Parameter In pd.ComponentDefinition.Parameters.UserParameters
	Try
		td.ComponentDefinition.Parameters.UserParameters.AddByValue(p.Name,p.Value,p.Units)
		Catch
			End Try
	Next
pd.Close(True)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 14 of 18
SpokenEarth
Yes, thought it would be handy having also the option for model par as well
Message 15 of 18
bradeneuropeArthur
Edit Something was wrong:
d.ShowOpen
Dim pd As Inventor.PartDocument = ThisApplication.Documents.Open(d.FileName , False)
	Try
		'msgbox (p.Units)
		Catch
			End Try
	Next
pd.Close(True)
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 16 of 18
SpokenEarth
It works perfect, thank you for the assistance.
Would it be to much if ask you to modify the code, I would rather not having true false statements
Achilles
Message 17 of 18
bradeneuropeArthur
What would you like to have modified?
Arthur Knoors
Drawing List!|
Workplane Resize!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Partlist Export!|
Vault Defer Update!
Message 18 of 18
SpokenEarth
An error appears
