iLogic - Update drawings of all parts associated with an assembly
Howdy All,
Does anyone know of a macro that will open every part in an assembly that has a drawing, updated, and save that drawing? Make a pdf of the drawing and dxf if sheetmetal would be a plus , but i'm not picky😎
bradeneuropeArthur
Are you using Vault?
Arthur Knoors
Programming Examples:
Drawing List!|
Toggle Drawing Sheet!|
Workplane Resize!|
Drawing View Locker!|
Multi Sheet to Mono Sheet!|
Drawing Weld Symbols!|
Drawing View Label Align!|
Open From Balloon!|
Model State Lock!
Posts and Ideas:
My Ideas|
Dimension Component!|
Partlist Export!|
Derive I-properties!|
Vault Prompts Via API!|
Vault Handbook/Manual!|
Drawing Toggle Sheets!|
Vault Defer Update!
chandra.shekar.g
Autodesk Support
Autodesk Support
@Anonymous,
Hoping that suggestion in the below forum link may be helpful.
https://forums.autodesk.com/t5/inventor-customization/batch-pdf-export-from-assembly-not-working/td-p/7791173
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
No I'm not...i'm actually using ProductStream
